YARBO SP-1100PW Triple Shielded Power Cable OCC 5.53mm² Ø16.5mm
YARBO SP-1100PW Triple shielded power cable OCC 5.53mm² Ø16.5mm
4.6 / 5
Reference : 6456
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Câble au mètre
This cable consists of 3 conductors of large cross-section, has a double shielding against electromagnetic interference
This shielding is composed of a layer of PTFE per strands as well as a braid of copper shielding.
Each conductor is composed of several 7 strands of monocrystalline OCC copper (black and red), the earth of 3.
They are insulated with a layer of PTFE, copper strip then PVC./ P>
Despite its diameter of 16.5mm this cable is relatively flexible
It will guarantee a dynamic and detailed sound reproduction.
Features:
  • Phase and Neutral conductors: 7x1 mm = 5.53 mm² OCC insulation PTFE + copper strip + sheath PVC
  • Earth conductors: 4x1 mm = 3.16 mm² OCC insulation PTFE + strap copper + sheath PVC
  • The ensemis again shielded by a copper strip and a thick PVC sheath
  • https://www.audiophonics.fr/images2/6456/6456_YARBOSP1100PW_1.jpg
    https://www.audiophonics.fr/images2/6456/6456_YARBOSP1100PW_2.jpg
Diameter (mm)16.5
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)5.53
ConnectorN/A
Ground / ShieldingYes
38 reviews
One of the best D.I.Y. power cables
After a very long burn-in time, I share the other reviewers praise of the cable. I use copper / rhodium plugs in both ends, but it is system depend, whatever plugs you choose.
This review has been posted for YARBO SP-1100PW Triple Shielded Power Cable OCC 5.53mm² Ø16.5mm
Sans intérêt
Monté avec des fiches Viborg haut de gamme plaquées argent, ce câble est gras et terne.
Après 200 h de rodage il n'y a pas eu d'amélioration. Je me suis laissé tenté suite aux différents avis très élogieux mais le résultat est très décevant.
Bande passante restreinte, beaucoup de grave mais un grave lourd, un medium/aigu mate pour ne pas dire terne …
Vraiment à éviter surtout au vu du prix qui ne justifie absolument pas son achat. Je l'ai remplacé par un Cardas Clear Power et c'est le jour et la nuit.
Certes le Cardas est beaucoup plus cher. Le Yarbo SP 1100PW était monté sur un préampli Mark Levinson 38S.
Je l'ai installé sur une alimentation Sbooster et la c'est moins mauvais. Du Furutech ou de l'Oyaide donneront des résultats bien supérieurs et ce sans forcer !
A méditer avant tout achat pour éviter de perdre du temps et de l'argent !
 (5)
YARBO SP-1100 PW
Une autre planète pas la peine d'aller plus loin wow WOW c'est quoi ce câble YARBO IL Y A QUOI dans le câble rapport qualité une tuerie monté avec les Viborg je suis bouche B je recommande à 10000000%.
Un peu long à monter mais le résultat est là.
YARBO J'y suis j'y reste un point c'est TOUT je vais commander d'autres c'est sur WOW WOW!! merci encore Audiophonics
 (3)
zimmerman
I give it 10 stars I love this cable can only recommend it to anyone how wants good
natural with large sound stage
Excellent !
Mes câbles secteurs étaient tous des Pangea AC14SE, très bons pour leur tarif, mais je souhaitais expérimenter quelques choses plus haut de gamme avec 2 câbles DIY, le Furutech TCS31 et ce Yarbo SP-1100PW, tous deux avec des prises secteurs Viborg VE502S en cuivre pur plaquées argent, en tous point excellentes.
J'ai réalisé de nombreux essais avec ces deux câbles secteurs, sur l'ampli (un Elekit TU9200, petit ampli à tubes à simple étage de 7581A Tung-Sol + Psvane 12AU7, merveilleusement musical), le DAC (Denafrips Ares II) et la barrette secteur. Ces deux excellents câbles secteurs ne sont pas des concurrents mais par contre, ils se complètent à merveille, à la condition de les placer judicieusement dans votre système audio.
Le combo magique chez moi est le Yarbo entre la prise murale et la barrette secteur et le Furutech TCS31 entre la barrette et l'ampli.
Le remplacement du Pangea par le Yarbo apporte une scène sonore en 3D étonnante, large et surtout profonde, des voix sans aucune sifflante, pures. C'est d'ailleurs souvent une constante avec le cuivre OCC, une impression d'une reproduction musicale pure et naturelle.
Le Furutech TCS31 apporte lui une grande richesse harmonique, des voix charnelles, émouvantes, un grave qui descend très bas. C'est une écoute pour ceux d'entre nous qui recherchent une proximité avec les artistes, le jeu des musiciens, les voix, presque une communion.
Tout le contraire d'une écoute exacerbée et démonstrative, presque intime, vraiment sublime sur les voix, les instruments acoustiques, le jazz vocal, la musique baroque, les voix de Brel, Nougaro, Stacey Kent, Youn Sun Nah, Véronique Gens...
La dynamique est effectivement sage ici et la douceur l'emporte, avec quand même une analyse troublante sur les voix, mais qui demeurent charnelles et douces. Si vous vous reconnaissez dans cette description musicale, ce combo est fait pour vous !
Sinon, pour une écoute plus transparente et dynamique, une analyse plus poussée, mieux vaut aller voir ailleurs.
Étonnant et un peu mystérieux de constater à quel point des câbles secteurs peuvent apporter tellement sur la reproduction musicale.
 (3)
