1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 2.5m (Pair)
1877 PHONO NOVA-OCC Câbles d'Enceintes Banane 2.5m (La Paire)
These 1877Phono Zavfino Nova-SPK banana speaker cables are positioned on a top-of-the-range cable segment, designed to offer exceptional performance thanks to flawless signal transmission. To do this, no design step is left to chance and the selected components are processed to provide their full potential.
4.9 / 5
By buying this product you get 38 loyalty points
Reference : 7406
389,00 €tax incl.
324,17 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
1877PHONO NOVA-SPK
Banana speaker cables PC-OCC Gold plated 3.31mm² 2.5m (Pair)
PC-OCC Copper & Silver Plating
The Nova-SPK integrates single-crystal PC-OCC Copper Litz conductors with a cross-section of 12AWG / 3.31mm². These ensure excellent audio signal transmission due to optimal conductivity. The Litz yarn structure considerably reduces the skin effect. These conductors also benefit from a silver plating to increase conductivity even further.
The conductors have a double dielectric isolation to drastically limit harmful interference to the audio signal and sound reproduction. In addition, the cable has two large EVA splitters to reduce vibration.
1877Phono Nova-SPK câbles d'enceintes Deep Cryo Treated
Deep Cryo Treated
This is a cryogenic treatment at two temperature levels, -186°C and -196°C, depending on the nature of the material used. This treatment optimizes the conductor crystals with the sole aim of providing the best possible transmission of the audio signal.
Ultra Sonic 7
After extrusion, Nova-SPK Copper goes through a thermal high voltage surface cleaning process, close to electrolysis and more efficient than cleaning with a conventional cleaning agent. The result is a very pure conductor and the extraction oils and surface heating residues are completely eliminated. This process also makes it possible to obtain a ready-to-use cable, already ground in and offering an optimal result from the first musical notes on a high-end HiFi system.
1877Phono Nova-SPK câbles d'enceintes traitement Ultra Sonic 7
Technical carateristics
SpEcifications
Product typeSpeakers cable
Length2.5m
ConnectorsBanana gold plated 24k"
Conductors materialsPC-OCC Copper (Litz wire)
Section12AWG (3.31mm2)
Conductors platingSilver
Conductors pin platingGold
InsulationDual dielectric
SheathPVC (105c)
Protection sheathBraided fiberglass
SplittersEVA (anti-vibrations)
Cable diameter17mm
Splitters diameter35.3mm
CoulorBlack, purple and silver
QuantitySold by pair
Length (m)2.5
ShieldingYes
Section (mm²)3.30
ConnectorBanana
8 reviews
Changement d'écran !
Ces câbles m'ont fait passer du 4/3 au 16/9, d'un LCD 46" à un écran 4K Oled 55". J'avais déjà un beau rendu, j'ai le cinéma scope maintenant.
This review has been posted for 1877PHONO NOVA-SPK Bananas Speaker Cables Silver Plated PC-OCC Copper 3.31mm² 2.5m (Pair)
Excellent rapport qualité prix
Ils relient désormais mon Atoll IN300 à mes Atohm GT1.
Je vais faire simple:
Excellent câbles, capables de se mesurer à de très bons câbles au double du prix.
Câbles HP très qualitatifs et surtout très homogènes:
Les aiguës ne sont jamais agressifs, les médiums sont très propres, et les graves sont toujours bien tenus, la contrebasse est un vrai régal...
Le service Audiophonics est toujours au top.
pas mal pour le prix
arrivé sans aucun probleme.question livraison sais nickel.le cable et pas mal.mais comme dit un autre audiophile domage qu il se plie pas dans l autre sens.vus la place entre mon meuble et les enceinte sais difficile de trouver la bonne place.je vais devoir acheter ou bricoler des supports en bois..les prises par contre sont un peut cheap.le systeme de bloquage fonctionne mais il faut bien bien serrer..je changerais par la suite pour des pure cuivre occ plaqué argent et pas or fin.par apport a mes petit octagon de chez raven le prix entre les deux et simplement le double..je ressens apres une heure d ecoute une pleinitude un naturel parfait..aigus subtil et doux medium present et bien timbré et des basses ferme .ont sens bien la peau d un gembé et les cordes d un violon sont tres beaux.equilibre neutralité et dynamisme .la transparence et pas mal et l image stereo n est pas plus grande que sur un octagon..sependent il na que deux heures d ecoute..sa vas devenir interessant apres 50/60h de musique.bon achat..le prix et bien doux et realiste ..je recommande se cable pour ceux et celles qui cherche un bon cable pas cher qui met en valeur la source et l ampli..neutre je vous dit..bonne ecoute
La claque aux câbles 3 x plus cher
Suite à un changement de Dac qui a envoyé le Dac Audio GD à la cave, j’ai voulu mettre à niveau les câbles en remplaçant les 1877phono par des Nordost blue heaven... 3 x le prix des 1877phono cela a duré 48h je suis revenu au 1877phono à cause des médiums et de l’air qui circule dans le musique. Il n’y a plus de doute pour moi ces câbles sont des merveilles sur mon ensemble Piega/Devialet.
Merci pour cette trouvaille. Bravo à Audiophonics et les autres foncez si vous manquez de 3D dans les voix!
NOVA SPK OCC
Bonjour,
Livraison sérieuse et rapide comme d'habitude. Les câbles très bonne finition , ca respire la confiance.
Seul bémol la gaine est très rigide et impossible de les dérouler dans un autre sens pour le branchement donc obliger de croiser les câbles pour respecter les polarités.
Sens de branchement Z côté ampli et O côté enceintes.
En 40 ans de haute fidélité j'en ai eu des câbles HP et de marques très connues bien plus onéreuses.
Les NOVA sont des câbles , très doux et fluides.
Encore pas rodés je suis très satisfait , naturel , détaillé , jolie timbres, aucune agressivité et dureté , du relief et de la matière, aigu sans crispation , médium chaleureux , grave tonique , image large et profonde ..Un câble qui laisse la musique s'épanouir de façon très reposante et les CD s'enchainent sans se poser de question.
Je recommande ce câble sans modération à ce prix Bravo ZAVFINO ..
 (4)
These 1877Phono Zavfino Nova-SPK  banana speaker cables  are positioned on a top-of-the-range cable segment, designed to offer...
