1877PHONO THE MAJESTIC MKII RA Phono Cable DIN Coudé - 2 RCA 1.5m
1877PHONO THE MAJESTIC Phono DIN Curved Cable - 2 RCA 1.2m
4.0 / 5
By buying this product you get 31 loyalty points
Reference : 4773
315,00 €tax incl.
262,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
The cable "THE MAJESTIC MKII" of the Canadian brand 1877PHONO allows to connect your reading arm with connector 5 Pins on a Phono preamplifier with RCA plugs *.
Resolutely Audiophile in its design, it is especially useful for connecting old record players to our modern equipment, leaving them an additional chance to amaze us by their inimitable analog sound.
Mthe MAJESTIC is distinguished by the use of 4 copper conductors OCC monocrystallineof an individual diameter of 0.40 mm, insulated by means of a thermoplastic film Teflon®-FEP of origin Dupont.
This second material, of French design, is renowned throughout the world for its excellent chemical resistance , hisexceptional electrical properties , and hisincredible thermal resistance (-240 to + 205 ° C). In addition, Teflon® FEP is a flame retardant productproven efficiency, which gives it a ASTM certification D-3418.
This first isolation is backed up by a shielded copper screen , himself enclosed in a Aluminum / Mylar strip to improve the immunity of drivers against perturbations radiophonic (RFI) and electromagnetic (EMI).
Come next 2 individual PVC sheaths reinforce the "physical" protection of drivers while providing flexibility and flexibility to the cable as a whole PET antistatic coating(Polyethylene Terephthalate ).
The black PVC outer sheath provides greater resistance to the harshness of the outside world. It is covered with a superb nylon black and blood sheath which, with the solid beech partition box , gives the MAJESTIC an inimitable cachet.
Connectors also show the manufacturer's zeal, and his propensity to always use the best: Thus the 5-pin DIN plug consists of non-magnetic copper plated with fine gold 24k andTeflon insulated , excuse the bit ...
The RCA are not left behind and also benefit from a 24k Gold and Teflon Insulation . Finally, it should be noted that each link is made using welding containing 5% silver.
It is therefore with a certain pride that AUDIOPHONICS has become the exclusive distributor of 1877 PHONO products for France.
*NOTE :This cable can not be used to connect a turntablee-disc on a conventional line input (CD, TAPE, AUX ...). In order to operate, it requires an input on RCA sockets of higher sensitivity, generally accompanied by a grounding, and leading to a correction filter conforming to the RIAA standard. This type of input is generally labeled "PHONO" or "TURNTABLE" on integrated preamplifiers and amplifiers.
Specifications:
  • Number of Drivers: 4
  • Composition of Conductors: Copper OCC of Section 0.40mm²
  • Input: DIN 5 pin plug Copper Plated 24k Gold & Insulated Teflon
  • Output: 2 RCA Plugs + 24k Gold Plated Ground & Isolated Teflon
  • Shielding: Braided Copper Sheath, Aluminum / Mylar Sheath, PET Insulation Sheath ( Polyethylene Terephthalate )
  • Total Cable Length: 1.50m
  • Finish: Black & Red Nylon Sheath
Length (m)1.5
ShieldingYes
Section (mm²)0.40
ConnectorDIN
ConnectorRCA
2 reviews
THE MAJESTIC
APRES PLUS D'UN MOIS D'ECOUTE LE CABLE S'EST OUVERT LE MEDIUM EST PLUS PRESENT ET LE SON EST ENCORE PLUS COHERENT. IL S'AGIT VRAIMENT D'UN TRES BON PRODUIT, SUR MA LINN IL REMPLACE UN CABLE VAN DEN HULL QUE JE TROUVAIS AGRESSIF ET SANS NUANCE. DE PLUS J'AVAIS POSSEDE AUPARAVANT LE MODELE HIGHLANDS DU MEME FABRICANT MAIS JE PREFERE CELUI-CI PLUS COHERENT ME SEMBLE T-IL. DONC UN TRES BON CABLE AU TRES BON RAPPORT QUALITE PRIX ET QUI CONSTITUE UNE TRES BONNE AFFAIRE.
This review has been posted for 1877PHONO THE MAJESTIC MKII RA Phono Cable DIN Coudé - 2 RCA 1.5m
1877PHONO THE MAJESTIC MK2 COUDE
BELLE PRESENTATION POUR CE CABLE, LE SON N'EST PAS ENCORE FINALISE PUISQUE LE RODAGE POUR UN CABLE PHONO EST SOUVENT ASSEZ LONG. SINON BELLE DEFINITION POUR UN CABLE VISIBLEMENT BIEN FABRIQUE, QUI SOUS CERTAINES MARQUES AMERICAINES OU ANGLAISES COUTERAIT FACILEMENT LE DOUBLE.
MAIS IL FAUDRA ATTENDRE ENCORE UN MOIS POUR SE PRONONCER SUR LE RENDU SONORE.
