PANGEA PREMIER SE BALANCED XLR Modulation Cable Balanced XLR-XLR 1m (A pair)
PANGEA True Balanced XLR Modulation Cable (unit) 1m
PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first obvious choice for a quality cable.
Strengths:
Real balanced cable with 3 conductors plus ground
High-end finish
High resistance XLR plug
Reference : 12396
149,00 €tax incl.
124,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
PANGEA Premier se BALANCED
XLR Modulation Cable Balanced 1m (A pair)
True Balanced cable structure
This cable is exceptionally manufactured with Cardas Grade one copper strands (hot spot) considered to be the best copper on earth and shielded with EMI / RFI silver and aluminium mylar plated insulation. In addition, these high-purity copper strands are sheathed in PE tubes using air as natural insulation derived from Pangea's premium cables. The topology of this cable is really symmetrical "Balanced" with three conductors plus a separate ground and not two conductors and a separate ground as on the cables falsely symmetrical.
XLR plugs with Black Carbon finish
A good cable is nothing without good XLR plugs and high quality contact quality. Particular care is taken in terms of contacts to its XLR plugs with gold-plated pins and a top-of-the-range "Black Carbon" finish.
Pangea Premier SE True Balanced Câble XLR 1m
Technical Caracteristics :
Conductor typePur Copper Cardas Grade One ( Hot point ) OFC 100 % copper ( cold point )
IsulationPE AIR TUBE
EMI / RFI shieldInsulation with aluminium mylar silver-plated foil
Jacket typeHigh-strength thermoplastic case
RCA conductorPlated Gold PIN high quality finish
Soldering typeHand made assembled
Lenght1m
PackageThe pair
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorXLR
Conductors material (Cable)Cardas Copper
2 reviews
An excellent XLR Balanced cable,properly designed.
Before using this cable I always had a very slight noise
in my right mono block amp/and no matter what I did
I could not eliminate it.With this cable it was instantly gone,
And of course it's construction quality is superior.
Thank you
Wayne AU
This review has been posted for PANGEA PREMIER SE BALANCED XLR Modulation Cable Balanced XLR-XLR 1m (A pair)
Pleinement satisfait
Câbles très bien finis, superbes connecteurs, tout cela pour un prix des plus raisonnables. A l'écoute, amélioration notable par rapport à la liaison rca, son plus dynamique; du tout bon pour ce qui me concerne. En résumé je recommande chaudement.
PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality...
