KINGSOUND KS-H4 Electrostatic Headphone HiFi Silver
By buying this product you get 99 loyalty points
Reference : 10321
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 09-05-2024.
Shipping from France
Billing in France
Technical support in France
The KINGSOUND KS-H4 is the nomadic evolution expected of the famous firm that will allow you to enjoy the best of the world of electrostatic music in roaming.
Particularly compact and lightweight, it is equipped with rotating axes at 90 ° for space saving and ease of use and the cable is independent of the helmet.
Havensi, it fits elegantly in its carrying pouch with a dedicated slot to accommodate the KINGSOUND M-03 amplifier and ESL extension cable.
Impricocheting with accuracy and clarity, he shows himself audacious at the top of the spectrum and very balanced in the low mediums.
He is also at ease to transcribe electronic music on an acoustic instrumental or a cappella singing.
A real revolution in listening to the headphones at this price, it will offer you the sound reproduction of a classic amplifier system and speakers to several tens of thousands of euros.
You will not listen to a simple headphone but music in the best possible conditions of reproduction to date thanks to an exceptional technology.
How does it work?/ Em>
The electrostatic loudspeaker is a simple concept, but difficult to implement successfully in practice.
The operation is based on the electrostatic attraction of the sameso that a piece of paper is attracted by a friction balloon.
The ultra-thin membrane, electrically charged, is stretched and placed between two metal grids.
When a high voltage audio signal is applied to the metal grids, the diaphragm moves to the grid in response to the signal.
At this moment, it has an opposite charge and is away from the gate which has the same charge as the membrane.
The diaphragm reacts linearly, producing sound waves that reproduce very precisely the original sound.
Why is it better?
Imagine a normal loudspeaker from which the sound waves diffract over a wide angle. This causes a rapid decrease in volume and sound quality.
So imagine a flat electrostatic panel producing sounds of the same input signal.
This time, the sound waves are produced on a large flat surface: the diffraction is weak.
The volume thus decreases much less over the same distance./ P>
The electrostatic stereo system is the ultimate in audio reproduction.
A professional listening system with minimal distortion. It literally pushes the limits of the most sophisticated instruments in the world that try to measure its performance.
This is an experience that few stereo systems can approach.
The result is awide frequency range over the range that others can not afford.
Specifications:
  • Frequency response: 6Hz - 42kHz
  • Impedance: 115kΩ to 10kHz
  • Input level: 150mV (100V output)
  • Maximum output level: 116dB
  • Yield: 106dB at 100Vrms
  • Electrostatic Capacity: 139pF
  • Voltage: 550 V DC
Physical characteristics:
  • Chassis Brushed Aluminum
  • Anodized Silver
  • Axis of the rotating structure at 90 °
  • Detachable cable
  • Cable length: 1m
  • Supplied with a 380x260mm reinforced carrying pouch to accommodate documents, tablets or laptops
  • Headset Weight: 0.270kg
  • Weight of the pouch with helmet: 960g
HD fever
Test in French (Click here).
Kingsound KS-H4 award
The electrostatic headphonesthat Kingsound KSH4 received the highest distinction 2016
the coveted Audio Excellence Award
Illustration with a KINGSOUND M-03 portable amplifier (not supplied).
Illustration of the M-03 in its case, placed in the dedicated housing.
ColorSilver
Impedance (Ω)115
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)6
Highest frequency (Hz)42000
Excellent headphone
Thank you Audiophonics for all your support!!
This review has been posted for KINGSOUND KS-H4 Electrostatic Headphone HiFi Silver
