ON MC7912CTG LDO Linear Voltage Regulator -12V 1A (Unit)
The MC7912CTG is a fixed output LDO linear voltage regulator that can be used for many applications. In particular, it has been designed to work with the MC7800 series.
Reference : 14263
1,00 €tax incl.
0,83 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
ON MC7912CTG
Régulateur de Tension Linéaire LDO -12V 1A
ON MC7912CTG Régulateur de Tension Linéaire LDO -12V 1A
The MC7912CTG is a fixed output LDO linear voltage regulator that can be used for many applications. In particular, it has been designed to work with the MC7800 series. This controller uses an internal current limiter and thermal protection. With a suitable heat sink it can deliver a current of 1A.
Product typeLDO Linear Voltage Regulator
Output typeFixed
Rated output voltage-12V
Output current1A
Min. input voltage-35V
Max. input voltage-19V
Voltage dropout1.3V
Case typeTO-220
Number of pins3 broches
Max/Max operating temperature0°C / 125°C
Output voltage (V)-12.0
Output current (A)1.0
Input voltage (V)-35.0
The MC7912CTG is a fixed output LDO linear voltage regulator that can be used for many applications. In particular, it has been designed to work...
