MUNDORF MCAP EVO OIL Capacitor 450V 8.2μF
4.0 / 5
Reference : 7299
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Condensateur MUNDORF MCAP EVO OIL Condensateur 450V 8.2µF
Mundorf MCAP EVO Oil
The EVO series at Mundorf is intended to offer very high audio precision at a low price and with minimal space-use
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and with a proprietary geometry (Evolution Winding). The coil is then hand-mounted in a shell designed to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance8,20 µF
Voltage450V
Tolerance±3%
Diameter35
Lengthr27
Connct wire diameter1,0
Connect wire length (A)35
Connect wire length (B)60
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3.0
Capacitor capacitance8.2
Rated voltage (V)450.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Bon condensateur
Monté en parallèle sur un tweeter je n'ai pas entendu de difference avec un Mcap supreme. Monté en direct sur un tweeter c'et moins bon que le Mcap supreme ou le jantzen superior Zcap , le piano ne passe pas vraiment, c'est bon sur les voix,. Beaucoup mieux que le Mcap standard: moins de dureté , Montage 50% Evo Oil et 50% Mcap supreme en direct sur un medium cela donne un bon resultat et gomme le coté un peu analityque du Mcap supreme
This review has been posted for MUNDORF MCAP EVO OIL Capacitor 450V 8.2μF
