Long Female Jack DC 5.5/2.1mm Plug
Socket DC Jack 5.5 / 2.1mm Long
4.0 / 5
Reference : 13156
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Jack socket for mounting electronic component
Socket DC Jack Female
This base female Jack DC 5.1 / 2.1 mm is useful to install a power outlet in your DIY construction projects.
This is the superior size version of this jack connector. It is more suitable for thick casings.
Supplied with a rng and matching bolt, installation is made simple for a sustainable and reliable mounting.
Easy to install
Its connectors are wide enough for a clean and robust welding.
They are suitable both to the PCB mounting and in cable and welded installation.
This component can be used for prototyping as well as definitive or semi-definitive repairing / construction.
supply diy female jack
5.5 2.1 jack socket screw housing
Characteristics
TypeSocket DC Jack female
base dimensionsExternal: 5.6 mm
Pin: 2.1 mm
Length: 8.5 mm
overall dimensionsMax external diameter: 10.8
Hole diameter: 7.8 mm
PCB connectors Dimensions5.8 mm x 2.8 mm
Parts supplied
Base Jackx1
Boltx1
Ringx1
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
ConnectorJack DC
3 reviews
Medicre quality
Mediocre quality product, bought two, one does`nt work, it makes no contact to mass. There must be better quality.
This review has been posted for Long Female Jack DC 5.5/2.1mm Plug
Satisfaction de ma commande
Embase jack très précisément définie sur l'offre (dimensions, utilisation, ..) = aucune erreur possible d'acheter un produit ne correspondant pas au besoin. Livraison très rapide = BRAVO et merci, je recommande à tous ce professionnel.
Qualité correcte
Qualité correcte, ne pas trop chauffer quand même lors du soudage.
