AUDIOPHONICS U-Sabre USB DAC 24bit/96kHz SA9023 / ES9023 V2.2E TCXO Edition
4.8 / 5
11056
69,00 €tax incl.
57,50 € tax excl.
Accessories
Audiophonics U-Sabre
Audiophonics U-Sabre ES9023 TCXO
A DAC with an incredible sound.
The DAC Audiophonics U-SABER TCXO USB V2.2E evolves with an update of the PCB and the addition of a digital output in mini format TOSLINK 24bit 96Khz. The benefits of this nomadic DAC are many.
The quality of the components is of the very first order with capacitors from Vima, Rodenstein. So here is a DAC format of pocket with the great sound of Hifi devices of living room.
High precision TCXO USB DAC
The analog output has only two high quality film capacitors on its path. The auditory result is immediately tangible with greater freedom in the acute medium and a perfectly cut out grave register. A USB DAC with high-end features in a compact format. This new version features a mini Toslink 24/96 digital output paired with the 3.5mm analog output.
Compact and musical
Un DAC USB Audio Plug-and-Play Audiophile
The DAC Audiophonics U-Saber ES9023 USB powered on any laptop or computer has a 6V or 9V external power port for problems with USB ports with low amperage.
Audiophonics TCXO
The full-size 27Mhz TCXO Clock implemented in the Audiophonics U-SABRE TCXO provides the feeling and more differentiation in harmonics. Therefore this DAC is absolutely not tiring to listen thanks to a jitter (0.5PPM) reduced.
ES9023P
This high-definition nomadic DAC, equipped with the famous ES9023 SABER 24bit 96Khz, integrates the Hyperstream technology to compensate for the usual defects of the classic Delta Sigma DACs. The result is immediately tangible, with a feeling, a sound precision above the competing technologies Delta Sigma.
Linear technology LDO LT1763
This product can work like the old generations ie directly in USB, without additional power supply optimally thanks to its original low noise regulator Linear technology LDO LT1763.
CompatibilityPlug & Play on Windows, Linux et OS X
USB ModeAdaptative
DACAsynchrone Sabre ES9023
Direct Out(Minimum Analog Output Scheme)
Power SupplyNo external power required - External power supply 6V-9V DC
ClockHigh Precision TCXO (0.5ppm)
l'ASIO SupportYes (driver in attachments)
Input
USB InterfaceSA9023 (SAVIAUDIO) : 16/24 bit and 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz
I2S-
USB(We recommend the use of qualitative cable and length less than 1.5m)
Output
Jack 3.5mmLine (1.7V rms)
RCA Stereo1.7V rms
Optical mini toslinkMini Toslink format 24bit / 96kHz
Audiophonics ES9023 TCXO
Package content
Package audiophonics ES9023 TCXO
Recommended by the press
Culture HD Clubic Qobuz Micougnou
ComponentES9023
ColorNoir
StructureAluminium
Colissimo - TNT - SoColissimo
11 reviews
parfait
Je suis tres agreablement surpris par ce DAC. branché sur mon ordi portable (windows), les pilotes s'installent tres rapidement et tout seul. Rien a faire, juste à choisir le dac comme sortie. C'est le jour et la nuit par rapport à la carte son de l'ordi. Boitier tres petit, c'est parfait pour une utiisation nomade avec un son de grande qualité ! Prix vraiment petit par rapport a la qualite! c'est le 2eme produit siglé audiophonics que j'achete (ampli casque) et ce sont vraient de tres bons produits! a recommander!
This review has been posted for AUDIOPHONICS U-Sabre USB DAC 24bit/96kHz SA9023 / ES9023 V2.2E TCXO Edition
Super mais...
Ce DAC est super.
Depuis que je l'utilise, sur un ampli BC Acoustic, le son est libéré et plus spacieux.
Pour le prix....
Par contre, actuellement, les drivers ASIO ne fonctionne pas sur W10.
J’espère qu'une solution sera trouvé prochainement
bon rapport qualité prix
excellent pour un prix très abordable. Le plug in pour apple est instable au redémarrage.
Bonjour,
Qu'appelez vous le plugin pour Apple ?
Nous n'en connaissons pas pour ce périphérique.
En cas de soucis, raccourcissez la liaison USB.
Amélioration après six mois
Après 6 mois d'utilisation, j'avais envie de savoir s'il était possible d'améliorer la qualité déjà très bonne de ce petit DAC.
Mon "serveur" audio est basé sur un eeepc + Daphile, et la sortie USB réputée très bruitée. L'idée était donc d'isoler le lecteur de la sortie USB du PC, sans passer par une solution onéreuse du style Intona ou Regen, qui n'aurait pas de sens pour un Dac de ce prix.
J'ai donc démonté le cable USB et injecté du 5v (4.8v) propre via 4 piles en série.
La manipulation, très simple, améliore la restitution du Dac.
Pour les trois personnes qui ont effectué les écoutes avec moi, les améliorations dans l'ordre :
- basses plus précises. Cela saute aux yeux.
- transparence et aération supérieures. On entend des informations supplémentaires, et les notes et les instruments se détachent mieux.
- médiums et aigus un poil plus "sec".
Le saut qualitatif ne me semble pas aussi important que lors du passage de la puce du PC au Dac, mais il est quand même important.
Je vais donc peaufiner ce montage, probablement via un cable spécial vendu par Audiophonics. Pour la source de l'alimentation, soit un ifipower, soit une batterie de grande capacité.
Test effectué sur des enceintes B&W DM4 via un ampli Sansui AU-519 restauré en profondeur.
Excellent
Immédiatement reconnu, le jour et la nuit au niveau du son !!!
Bref on peut acheter ce petit DAC les yeux fermés....
