Copper wire of high purity with an inductance without distortion. It will suit all audio applications.
The coil sees modern design, self-supporting and with low inductance tolerance (± 5%)
The holding power depends on the thread used, especially the thickness of the copper wire: the larger the cable is thicker, the power capacity is high.
The copper used contains between 0.02% and 0.04% oxygen. This material is pure 99.9% and provides exceptional conductivity.
Characteristics | |
Type | Coil Air Core |
Material | Ringed pure copper 99.9% |
Inductance | 0.10 mh |
Power Handling | 200W RMS |
section wire | 0.52 mm² (20AWG) |
Type core | Free |
DC resistance | 0.21 ohm |
Dimensions | 32mmØ x 13mm |
