E1DA COSMOS GRADE B Balanced ADC ES9822Pro 32bit 384kHz
E1DA COSMOS GRADE A Balanced ADC ES9822Pro 32bit 384kHz
With the Cosmos, E1DA offers a high-end balanced ADC, whose analog-to-digital conversion stage is based on an ES9822Pro chip. It uses only high quality audio components to provide outstanding performance and measurements. The input is either balanced stereo XLR or balanced 2.5mm jack.
By buying this product you get 22 loyalty points
Reference : 16452
225,00 €tax incl.
187,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
E1DA Cosmos GRADE b
E1DA Cosmos ADC Symétrique ES9822Pro 32bit 384kHz
With the Cosmos, E1DA offers a high-end balanced ADC, whose analog-to-digital conversion stage is based on an ES9822Pro chip. It uses only high quality audio components to provide outstanding performance and measurements. The input is either balanced stereo XLR or balanced 2.5mm jack. For output, the Cosmos is equipped with a USB-C port, also taking care of powering the device and supporting a PCM stream up to 32bit 384kHz. The intelligent design of the ADC allows it to achieve an extremely low level of noise and distortion.
E1DA also provides the Cosmos Tweak software for Windows, through which it is possible to control the levels of harmonic distortion, the interpolation filters and the integration parameters of the ADC.
The bottom side of the device also conceals a DIP switch attenuator with 8 sensitivity levels, from 1.7V to 10V. Each sensitivity value has a different input impedance.
On the side of the USB-C output, two LEDs allow to indicate, by their blinking, the sampling rate of the flow (48kHz = 1 flash/2s, 96kHz = 1 flash/s, 192kHz = 2 flash/s, 384kHz = 3 flash/s). The color of the LEDs indicates the operating mode of the device (stereo: green, mono: blue).
All Cosmos ADCs are calibrated by the manufacturer. When using the Cosmos Tweak software, it is strongly advised to make a copy of the calibrated product values before any modification.
Product typeADC
ADC chipES9822Pro
OPAOPA1612
USB InterfaceCT7601CR
Inputs1x Balanced stereo XLR (up to 10Vrms)
1x Balanced Jack 2.5mm (up to '43Vrms)
Output1x USB-C
Sampling rates (output)PCM up to 32bit 384kHz
Latency5mS @ 192kHz
Input range / impedance1.7Vrms 640Ω
2.7Vrms 1kΩ
3.5Vrms 1.3kΩ
4.5Vrms 1.66kΩ
6.7Vrms 2.46kΩ
7.6Vrms 2.82kΩ
8.5Vrms 3.12kΩ
10Vrms 3.48kΩ
43Vrms 13.6kΩ
Frequency response5Hz - 180kHz @ 32bit 384kHz (according to interpolation filter)
SNR>127dB(A) / Grade B
THD+N0.00007% @ 1kHz, -0.5dBFS, SR48kHz, 20Hz-20kHz
SINAD>122dB (Grade B)
Crosstalk< -140dB @ 1kHz
Dimensions104 x 61 x 39mm
Net weight160g
Jitter test 12kHz : E1DA 9038SG3 to Cosmos ADC
Crosstalk, left channel 1kHz -0.5dBFS, right channel -152dB
InputJack 2.5mm
InputXLR
OutputUSB
DAC / ADC ChipES9822Pro
Max sampling rate384kHz
With the Cosmos, E1DA offers a high-end balanced ADC, whose analog-to-digital conversion stage is based on an ES9822Pro chip. It uses only high...
