DAYTON AUDIO DSP-408 4x8 Digital Audio Processor DSP ADAU1701 SigmaDSP 25/56bit 4 to 8 Channels
DAYTON AUDIO DSP-408 4x8 Digital Signal Processor DSP ADAU1701 SigmaDSP 25/56bit 4 to 8 Channels
Dayton Audio offers with its DSP-408 a Digital Signal Processor (DSP) intended to be simple to use. Thus, the device is both versatile, has excellent audio quality and offers a graphical interface (GUI) to simply apprehend the various settings to finally find the sound you were looking for.
4.6 / 5
Reference : 13043
215,00 €tax incl.
179,17 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
The supplied power supply requires a US to FR / EU adapter to be plugged into French sockets, available here.
DAYTON AUDIO DSP-408 Processeur de Signal Numérique DSP ADAU1701 SigmaDSP 25/56bit 4 vers 8 Canaux
In addition, the DSP-408 is very complete, offering 4 input channels and 8 output channels in RCA format. All the necessary connections to take full advantage of the settings allowed by the device.
Dayton Audio DSP-408 Processeur de Signal Numérique DSP ADAU1701 SigmaDSP 25/56bit 4 vers 8 Canaux
Take control of your sound
The DSP-408 offers a unique feature in the DSP world: the ability to use it at home or in a vehicle. This system will provide you with a single DSP model for all your audio processing and setup needs.
For many, the quest for sound perfection is an endless quest. By using the various features of the DSP-408, you can manipulate and improve the sound quality of your audio system simply. This will allow you to access all the following features and perfect your system in no time:
Software featuresp>
  • 10 band per channel parametric equalizer
  • High and low shelf EQ per channel
  • Variable crossovers : High/Low/Band-Pass slopes 0-24dB, Linkwitz Riley/Butterworth/Bessel
  • Delay : 0 to 277cm or 8.1471ms adjustable in 1cm steps
  • Input/Output mixing to customize the signal path
  • Phase adjustment
  • Custom 6 presets
  • Save, load and delete presets
  • Software controllable level attenuation on the preamp and high level inputs
  • Minimum / maximum voltage protection
  • Reverse voltage protection
  • Mute circuit and delay
Controllable interface via Windows
The DSP-408 is easily controlled directly from Windows software, specially developed by Dayton Audio. This application incorporates all the tools you may need to help your audio system perform at its best.
Despite the plethora of options and settings available in this software, Dayton Audio has made it easy to use and intuitive, so that everyone can get the most out of their hardware without necessarily having to have advanced technical skills and knowledge.
Dayton Audio DSP-408 Logiciel
Android application via Bluetooth connection (Optional)
Bluetooth dongle sold separately
Por you to make your settings directly from your Android smartphone, Dayton Audio offers a dedicated mobile application. This will allow you to enjoy all the features of your DSP, again via an ergonomic and simple graphical interface, but always complete. In addition, the settings with the application being made via Bluetooth, you can make your settings in front of your system, under optimal conditions. In addition, you can also use your smartphone as an audio source for quick testing.
The application is available directly on the Android Google Play by clicking on the button below.
To take advantage of this feature you must have the bluetooth dongle DSP-BT4.0 available here.
Wired remote control (Optional)
Remote controle sold separately
In a mobile environment, it can become more complicated to use the software or application to adjust volume and settings. Dayton Audio offers a wired remote control to control the volume and select your different profiles.
The DSP-RC remote control is sold separately and available here.
Dayton Audio DSP-408 Télécommande
ChipsetAnalog Devices ADAU1701 Sigma DSP 28/56 bit
Inputs4x RCA
Outputs8x RCA
High level inputsx4
High level inputs impedance180 Ohm
RCA inputs impedance>= 20000 Ohm
THD+N0.008%
Output impedance< 50 Ohm
Max input level>= 3.2V THD=1%
RCA output level3.5V RMS
SNR>= 115dB
Remote control output current> 500mA
Power supply12V DC 1.5A (included)
Dimensions166 x 115 x 26mm
Package1x DSP-408
1x power supply 12V 1.5A (Requires US to EU adapter)
Cable for high level input (16 pins)
1x USB-A to USB-B cable
2x Mounting brackets
Screws
Rubber pads
Max sampling rateNC
13 reviews
produit correct
Suite à installation et paramétrage sur mon système, le fait de passer du mode passif au mode active, plus de clarté et surtout aisance supplémentaire dans la reproduction musicale.
This review has been posted for DAYTON AUDIO DSP-408 4x8 Digital Audio Processor DSP ADAU1701 SigmaDSP 25/56bit 4 to 8 Channels
Trop de souffle sur les mediums-aigus
Petit appareil sympa, je pensais l'utiliser pour peaufiner mes réglages ou tout simplement pour le mettre en actif avec 3 amplis connectés pour mon système haut rendement ... mais que de souffle particulièrement dans les médiums et les aigus.
Comment supprimer ce souffle.
De plus, l'appareil ne filtre plus rien par intermittence lorsque le niveau du signal entrant diminue.
Merci d'avance si vous avez une solution pour corriger ces problèmes car sinon, ce petit dsp est bien pratique que ce soit via l'interface usb ou en bt depuis son telephone
Génial !
Avec ce petit appareil j'ai mis immédiatement au placard quarante années d'égaliseurs et de filtres actifs : l'interface sur PC est immédiate et totalement intuitive (je hais l'informatique !), la souplesse des réglages irréprochable, le tableau graphique unique parfait, clair et logique.
Vraiment super pour un prix dérisoire au vu des fonctions offertes. Juste prévoir un câble USB de 5 mètres pour pouvoir avoir le PC à la position d'écoute, mais sans objet pour ceux qui se serviront de leur téléphone (que je n'ai pas).
Toujours aussi satisfait
Le piège de ce type de produit est qu'il existe tellement de combinaison, que l'on se prend au jeu et que ça n'en finit jamais.
Ce ci dit, je suis toujours aussi satisfait par ce DSP, je voulais juste faire une mise à jour de mon expérience avec le DSP-408, je ne sais pas si le "défaut" est imputable à mon appareil seulement mais les filtres Butterworth et Bessel sont inversés et ce, sur tous les passe-bas et passe-haut paramétrables.
Lorsque l'on choisit une fréquence de coupure, par exemple 200 Hz, avec un filtre Butterworth cette fréquence doit se trouver à -3 dB et sur un filtre Bessel - 7/8 dB avec une pente plus douce.
Et bien lorsque l'on sélectionne un filtre Butterworth c'est un Bessel qui s'active, et inversement. Ce n'est pas très grave, il suffit de le savoir...
Compléments
Je suis toujours aussi satisfait de ce DSP.
Avec le recul, je complèterais mon avis en revenant sur l'interface androïde dont l'utilisation n'est pas des plus précise, surtout lors de l'utilisation des curseurs gain +/- ou facteur Q où il n'est pas possible à l'instar du réglage des fréquences, de renter une valeur.
Il est possible de choisir l'unité pour le réglage du delay en ms ou en cm (en " aussi).
En ms il y a le possibilité d'incrémenter de 385 réglages différents par pas de 0.0208ms alors qu'en cm, cette incrémentation est de 277 par pas de 1cm.
Je croyait que les deux évoluaient symétriquement, mais non.
Le réglage en ms est donc plus "précis" (de la à percevoir des différences)
Plus dans le domaine des suggestions, 3 voies et 10 fréquence pour chacune, j'aurais réparti les fréquences différemment en attribuant plus de fréquence au médium.
Par exemple sur les 30 dispos j'en aurais réservé 7 pour le grave qui demande dans mon cas moins d'intervention, 16 pour le médium qui demande lui plus fréquence et 7 pour l'aigu.
Pour une configuration active avec des coupures à 300/4000HZ par exemple je pense que ça aurais pu le faire.
Je suis en trois voies, mais en passif sur le passe bas et passe haut du médium/aigu, je dois donc utiliser une voies du DSP pour le mid/high donc ma coupure basse étant à 100hz 10 bandes de 100hz à 20khz, c'est un peu juste, ça oblige à faire des choix.
Dernières précisions, si vous voulez intervenir sur le 20khz, il faut lorsque l'on tape sur le clavier virtuel la fréquence, rentrer 19999.
J'ai intégré mon DSP avec sa clef bluetooth dans un coffret métallique, cela limite chez moi la porté BT à quelques mètres 5 environ.
Dayton Audio offers with its DSP-408 a Digital Signal Processor (DSP) intended to be simple to use. Thus, the device is both versatile, has...
