DAYTON AUDIO CS622C Ceiling Speaker Driver 25W 8 Ohm 89dB 60Hz - 20kHz Ø16.5cm
DAYTON AUDIO CS622C 6-1/2" Stereo Ceiling Speaker
Reference : 7525
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
The Dayton Audio CS622C is a very atypical loudspeaker: it has the distinction of being able to broadcast a stereo signal
These two channels allow the use of a single speaker in confined spaces (bathrooms, corridors, kitchens).
This specific design allows for a maintained stroke and maintaining the integrity of the stereo anywhere in the house.
Its structure based on two tweeters makes it possible to reproduce stereo with a single HP (the main polycarbonate membrane is intended for the reproduction of mediums and basses).
The system includes:
  • the speaker
  • the removable steel grid
  • Hardware and installation instructions
  • Sold individually
  • Cutting dimensions: 178mm 9.5mm round x 51mm-22mm depth
  • Overall dimensions: 203mm 9.5mm round x 51 22mm depth
Characteristics :
https://www.audiophonics.fr/images2/7525/7525_daytonaudio_cs622c_1.jpg
Power (max)Stereo / Dual-Channel
TECHNICAL SHEET
Speaker configurationCoaxial
Input voltage 8 ohms
Power (RMS)25 watts
50 watts
Frequency Response 60 - 21,000 Hz
Subwoofer typepolycarbonate
Woofer Diameter 152mm-13mm
Type tweeterDome Textile
Tweeter size25mm
Special Features
Grid TypeRemovable steel grille
[Img-12546-left-thickbox_default]
[Img-12545-left-thickbox_default]
https://www.audiophonics.fr/images2/7525/7525_daytonaudio_cs622c_6.jpg
https://www.audiophonics.fr/images2/7525/7525_daytonaudio_cs622c_7.jpg
https://www.audiophonics.fr/images2/7525/7525_daytonaudio_cs622c_2.jpg
https://www.audiophonics.fr/images2/7525/7525_daytonaudio_cs622c_4.jpg
https://www.audiophonics.fr/images2/7525/7525_daytonaudio_cs622c_5.jpg
https://www.audiophonics.fr/images2/7525/7525_daytonaudio_cs622c_3.jpg
Download the CS622C DataSheet 152mm-13mm Stereo
Speaker Power (W RMS)25.0
Speaker TypeCeiling Speaker
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typePolycarbonate
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)60
Highest frequency (Hz)20000
Très bon résultat
J'ai été agréablement surpris par le poids, la qualité des finitions et des matériaux. Le mode d'emploi aide à une installation facile (avec même une astuce pour localiser les obstacles invisibles avant de tout percer).
Il n'y a pas de recommandation sur le volume arrière, et j'en ai installé un dans un surmeuble de cuisine d'a peu près 100 litres et la courbe obtenue est très régulière (chute dans les graves progressive et propre vers 80 Hz comme attendu sur ce diamètre de HP). J'en ai installé un autre dans un faux plafond de salle-de-bain de gros volume (40cm de hauteur) et la par contre les graves tombent un peu trop vite et de manière chahutée entre 100 Hz et 80Hz, ce que je ne pourrai pas rattraper car la pièce est petite et en partie carrelée ce qui donne de multiples résonnances. Les 2 tweeters intégrés sont un peu trop sensibles par rapport au médium/grave : il y a une marche de plus de 5 db sur tout le spectre au dessus de 5khz, mais à l'oreille dans des locaux ou les medium sont trop présents a cause de surfaces proches en verres ou carrelage cela se passe très bien à l'oreille !
Je l'es ai alimentés avec des modules JAB2 V2 stéréo qui donnent 2x25W sur 2x8ohms et la marge de puissance est très importante même pour une pièce de 12m2. La diffusion stéréo rendue par les 2 tweeter cote à cote n'est pas très marquée ce qui n'est pas étonnant, mais cela évite le son plat du mono quand la musique est diffusée dans une seule pièce tout en se fondant très bien dans l'ensemble quand je diffuse en multi-room.
This review has been posted for DAYTON AUDIO CS622C Ceiling Speaker Driver 25W 8 Ohm 89dB 60Hz - 20kHz Ø16.5cm
