MONACOR SPH-8M Speaker Driver Woofer 100W 8 Ohm 89dB 35Hz - 2500Hz Ø20.5cm
MONACOR SPH-8M Haut-parleur de grave Hi-Fi 20.5cm
Reference : 5789
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Here is the MONACOR SPH-8M, a Hi-Fi bass speaker 150W max for 8 Ω.
  • Serial Hi-Fi, excellent playback quality
  • Damped polypropylene membrane, very low resonance
  • Solid aluminum bowl, 6-hole screw connection
  • Magnetic system with drilling of pole pieces
  • Ideal for bass-reflex and closed loudspeakers
Characteristics :
  • Impedance (Z): 8 Ω
  • Resonant Frequency (fs): 35 Hz
  • Maximum bandwidth: f3-2500 Hz
  • Maximum power: 150 W < MAX
  • Nominal power (P): 100 W RMS
  • Average sound pressure (1 W / 1 m): 89 dB
  • Compliance susp. (Cms): 0.71 mm / N
  • Weight (Mms): 27 g
  • Mechanical overvoltage. (QMS): 2.26
  • Electrical overvoltage (Qes): 0.50
  • Fact. total surge (Qts): 0.41
  • Volume equ. (VAS): 44 l
  • DC resistance. (Re): 6.5 Ω
  • Force Factor (BxL): 9.01 Tm
  • Coil Inductor (Le): 0.78 mH
  • Coil diameter: Ø 38 mm
  • Coil Holder: Aluminum
  • Linear excursion (X MAX ): ± 4,5 mm
  • Emission area (Sd): 240 cm 2
  • Weight: 790 g
  • Weight: 2.1 kg
https://www.audiophonics.fr/images2/5789/5789_SPH-8M.jpg
https://www.audiophonics.fr/images2/5789/5789_SPH-8m2.jpg
Speaker Power (W RMS)100.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)205.0
Diaphragm typePolypropylene
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)22.0
Lowest frequency (Hz)35
Highest frequency (Hz)2500
rapport qualité/prix au rdv
utilisé en remplacement sur des JBL MODEL 4301B ,Fréquence de coupure max de 2500hz en total accord avec le tweeter LE26, le rendement sonore est parfait (ps: pour les puristes , pensé a redimensionner l’évent bass reflex on sort la dremel), des bass très agréables car la fréquence mini reste honorable pour ce prix.
This review has been posted for MONACOR SPH-8M Speaker Driver Woofer 100W 8 Ohm 89dB 35Hz - 2500Hz Ø20.5cm
