Heatshrink Tube 4: 1 Ø16.0mm Length 1m (Black)
Gaine Thermo Rétractable 4:1 Ø16.0mm Longueur 1m (Noir)
Reference : 4690
4,33 €tax excl.
Available
Shipping date: 16-07-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Thermo-retractable sleeve with a ratio of 4: 1, internally equipped with an adhesive layer ensuring better maintenance on any type of surface (plastic, rubber, metal ...)
Thickness of intermediate size studied to provide excellent protection to mechanical strength, while maintaining a high degree of flexibility.
Adapts to irregular shapes and provides a high degree of insulation and waterproofing. Product is halogen-free, flame retardant, and RoHS certified.
A ratio of 4: 1 means that the diameter of the sheath once heated will be divided by 4: for example for a 12mm sheath, after being heated its diameter will be 3mm.
Diameter: 16.0mm => about 4.0mm after retraction
https://www.audiophonics.fr/images2/GAINES-THERMO_1.jpg
Specifications:
  • Retractable Ratio: 4: 1
  • Longitudinal Retracting Ratio: ± 8%
  • Shrink Temperature: 70 - 120 ° C
  • Melting Temperature of Internal Adhesive Layer: 70 - 90 ° C
  • Sheath Thickness After Shrinkage: +/- 2.00mm
  • Temperature Resistance: -45 to + 125 ° C
  • Rigidity Dielectric: ≥15 Kv / mm (IEC243)
  • Certifications: RoHS
  • Diameter: 16mm
  • Length: 1m
  • Color Black
Diameter (mm)16
Colissimo - TNT - SoColissimo
materiel ok, emballage inadapté
gaines reçues pliées dans des sacs de 8cm.... donc beaucoup de pertes à cause des pliures..
This review has been posted for Heatshrink Tube 4: 1 Ø16.0mm Length 1m (Black)
