By buying this product you get 99 loyalty points
This is the Maple version, with maple base (light wood)
Regulated linear power supply for Nativ Vita and Wave
Based on the principle that the sound quality depends greatly on the power supply of the system, Nativ offers the Pulse. This power supply features an ultra-sophisticated linear design, featuring customized components for analog and digital sections, low-noise linear regulators, a shielded toroidal transformer built on specifications and an AC line filter, all to get the most out of your audio system.
<!- RIGHT IMAGE / LEFT TEXT ->
The Nativ Wave is composed of specific power supplies for each analog section and for digital circuits. The best controllers have been selected to protect the analogasite thus removing the jitter. With a capacity of more than 50000μF, this linear power supply will provide the power required for your system with great ease, allowing the system to go from total silence to amazing dynamics in an instant.
The Nativ Wave also incorporates a totally separate SMPS power supply that delivers stable current for non-audio components. This, extremely efficient, produces only a small noise below 50mVp-p at full load (5V).
Nuvotem Talema has designed exclusively for Nativ a toroidal transformer to measure, allowing to provide a clean and stable current without vibration, reducing noise even more. For this, it uses a design which is distinguished by an extremely weak electrostatic magnetic field.
The Nativ Pulse shows a great quality of design, starting as soon as it enters. To do this, it incorporates a filterAC, manufactured by Schurter, with high attenuation, thus eliminating virtually all interference and EMI / RFI noise.
The high-quality 7000 Aluminum Pulse housing has a reflective design, even in its chassis. This anti-magnetic housing protects the components of the power supply from electromagnetic and mechanical interference, but also eliminates the negative effects of long-term thermal radiation. The power supply also features a dual tilted display (2 x 2.7 ") for displaying spectrometer information, such as voltage, current and power for inputs, in a readable manner.
www.audiophonics.fr/img/cms/products/12267/Nativ-Pulse-ultra-low-noise-linear-power-supply-homepage-5-GUI-high-res.jpg "alt =" Nativ-Pulse-ultra -low-noise-linear-power "/>SPECIFICATIONS | |
Tension / Current | DC + 12V 5A - DC +/- 15V (0.5A) |
Design | linear |
Total capacity | 50,000 μF |
<controllers/ Td> | 25x linear regulators |
Toroidal transformer | Nuvotem Talema |
Power filter | Schurter anti EMI / RFI |
<compatibility/ Td> | Designed to work with DAC Nativ Wave and Nativ Vita network player |
chassis | Aluminum 7000 and wood |
Infrared remote control | Yes |
Input | IEC C14 |
Output | NC |
Color | Érable |
Color | Other |
Color | Black |
Output voltage (V) | 12.0 |
Output current (A) | 5.0 |
Output current (A) | 0.5 |
Input voltage (V) | 120.0 |
Input voltage (V) | 230.0 |
Power Supply | Linear |
