Medium High-end speakers MS-100CHQ (The pair)
Haut-parleurs de medium High-end MS-100CHQ (La paire)
Reference : 1315
104,00 €tax incl.
86,67 € tax excl.
A CARPOWER high-end midrange that makes the car (and if so desired from the dining room) a concert hall: an almost unique restitution, a salad bowl latest generation, an optimized membrane and a great power: all this for a really optimal price.
Pair of midrange speakers Top Class, 4 Ω
for demanding applications. Already from 200 Hz, ideal starting at 300 Hz, with an absolutely perfect behavior up to the range of mediums and combinable with any high-speaker. This medium loudspeaker is convincing in a car in the dashboard or the doors, or even the rear aisle (in this case or for very open installations, a cabinetry of 0.5-1 liter is recommended). The sound quality is simply excellent, use with different high tech or "kickbass" and high-pitched speakers in the car, just like Hi-Fi at home, sets new standards.
ze = "2">Delivered in pairs.
blank.gifImpedance (Z) blank.gif4 Ω
blank.gifFrequency responsee resonance (fs) blank.gif105 Hz
blank.gifMaximum bandwidth blank.giffx-5000 Hz
blank.gifMaximum power blank.gif150 WMAX(300-5000 Hz)
blank.gifNominal power (P) blank.gif60 WRMS
blank.gifAverage sound pressure (1 W / 1 m) blank.gif90 dB
blank.gifCompliance susp. (Cms) blank.gif0.46 mm / N
blank.gifMovable mass (Mms) blank.gif4.7 g
blank.gifMechanical overvoltage. (Qms) blank.gif2.22
blank.gifElectrical overvoltage (Qes) blank.gif0.55
blank.gifFact. total overvoltage (Qts) blank.gif0.44
blank.gifVolume equ. (VAS) blank.gif2 l
blank.gifDC resistance. (Re) blank.gif 3.2
blank.gifForce factor (BxL) blank.gif4.4 Tm
blank.gifInductance coil (Le) blank.gif0.2 mH
blank.gifCoil diameter blank.gif25 mm
blank.gifCoil support blank.gifAlu
blank.gifLinear Excursion (X MAX)blank.gif± 1.5 mm
blank.gif Transmitting area (Sd) blank.gif55 cm2
blank.gifblank.gif8 oz.
PDF Download
Colissimo - TNT - SoColissimo
