This LHY AUDIO LPS50VA regulated linear power supply ensures high stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this dedicated audio power supply, and it will pair perfectly with your 9V HiFi equipment.
This power supply includes a custom OFC copper-wound transformer coupled with an AOP 177 for more accurate voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 9uV.
The power supply benefits from an aluminum alloy case for efficient heat dissipation and a GX16 aviation output. There's also a switch for disabling grounding to avoid ground noise. Finally, you can adjust the output voltage on the back of the unit by ±0.5V if required.
Please use the GX16 cable supplied. GX16 Audiophonics cables are not compatible. Please also check the polarity of the two pins.
Input voltage | 230V |
Output Voltage / current | 9V 4A Max 9V 2A Continuous |
Outputs | 1x Plane GX16 |
Input | IEC |
Case material | Aluminium alloy |
Dimensions | 110 x 155 x 63mm |
Weight | 1.114kg |
Package | 1x LHY AUDIO LPS50VA 1x Plane GX16 to DC 5.5/2.1mm male jack cable 80cm 1x power supply cable |
Input | IEC C14 |
Output | GX16 |
Color | Black |
Output voltage (V) | 9.0 |
Output current (A) | 4.0 |
Input voltage (V) | 230.0 |
Power Supply | Regulated Linear Power Supply |
