CELESTION CDX1-1430 Horn Speaker Driver High Range 50W 8 Ohm 2000Hz - 20kHz Ø 2.5cm
Chambre de compression CELESTION CDX1-1430
Reference : 1283
136,34 €tax incl.
113,62 € tax excl.
Even in the field of horn speaker systems, the CELESTION range offers interesting alternatives with excellent technical properties.
Horn motor, 100 W MAX , 8 Ω
1 "horn motor with standard mounting 2 or 3 screws, neodymium motor system in new design, cooling, low weight, compact dimensions Very linear frequency response, very high efficiency for very low distortion: the acoustic values ​​indicated result from the combination with the MRH-200 horn. From 3000 Hz approximately, applications in 2-way systems or even with low 15 "are possible with this engine.
blank.gif Impedance (Z) blank.gif 8 Ω
blank.gif Resonance frequency (fs) blank.gif 1750 Hz
height = "1" src = "http://www.monacor.com/global_img/blank.gif" width = "10" alt = "blank.gif" /> blank.gif
blank.gif Maximum bandwidth blank.gif fx-19000 Hz
blank.gif Crowds. cutoff (fmax.) (12dB / oct.) blank.gif 3000 Hz
blank.gif Maximum power blank.gif 100 W MAX
blank.gif Rated power (P) blank.gif 50 W RMS
blank.gif Pressure sound. (1W / 1m) blank.gif 110 dB
blank.gif Angle dispersion (green / hor) blank.gif according to flag
blank.gif Coil diameter blank.gif 34.4 mm
blank.gif Magnet diameter blank.gif 75 mm
blank.gif cutting blank.gif according to flag
blank.gif Mounting depth blank.gif according to flag
blank.gif Dimensions blank.gif Ø 75 mm x 75 mm
blank.gif Weight blank.gif 450 g
CTS
PDF-Download
Speaker Power (W RMS)50
Speaker TypeChambre de compression
Impédance8
Diamétre Haut Parleur (cm)25
Colissimo - TNT - SoColissimo
