MONACOR MSH-116/4 Speaker Driver Midrange 40W 4 Ohm 91dB Ø 11cm
Monacor MSH-116/4 Midrange loudspeaker 4 ohm 5" (unit)
15%
Reduced price!
Reference : 1204
Limited special offer
51,90 €tax incl.
-15%
44,12 €tax incl.
36,76 € tax excl.
Available
Shipping date: 22-10-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
A medium-sized speaker with outstanding reproduction qualities thanks to the materials used. The impedance of 4 Ω allows its use in embedded Hi-Fi.
Hi-Fi Medium Speaker, 4 Ω
Wide bandwidth, very low mobile mass and mobile coil on high temperature kapton support. Extra-flat bowl, decompression and core cooling that participate in the excellent impulse response.
Klang + Ton 2/01
"This loudspeaker is the surprise of the test.
Impedance (Z) 4 Ω
Resonance frequency (fs) 95 Hz
Maximum bandwidth fx-10000 Hz
Maximum power 120 W MAX (400-5000 Hz)
Rated power (P) 40 W RMS
Average sound pressure (1 W / 1 m) 91 dB
Compliance susp. (Cms) 0.62 mm / N
Moving mass (Mms) 4.6 g
Mechanical overvoltage. (Qms) 2.38
</ Span>
Electrical overvoltage (Qes) 0.48
Fact. total surge (Qts) 040
Volume equ. (VAS) 2.7 l
DC resistance. (Re) <img src = "http://www.monacor.de/global_img/blank.gif" alt = "" width = "10" height = "1" /> 3.2 Ω
Force factor (BxL) 4.3 Tm
</ Span> Inductance coil (The) 0.18 mH
Coil diameter 25 mm
</ Span>
Coil holder Alu
Linear Excursion (X MAX ) ± 1 mm
Transmitting surface (Sd) 55 cm 2
Magnet Weight 8.5ounces
Weight 0.6 kg
[Img-20541-left-thickbox_default]
[Img-20540-left-thickbox_default]
[Img-20539-left-thickbox_default]
Speaker Power (W RMS)40
Speaker TypeMidrange
Impedance (Ω)4
Loudspeaker diameter (cm)110
Diaphragm typePaper
Efficiency (dB)91
Xmax (mm)1
Highest frequency10000
Colissimo - TNT - SoColissimo
