SUPRAVOX 285-2000 Speaker Driver Full Range 70W 8 Ohm 101dB Ø 28cm
Supravox 285-2000 - 28 cm - 101 dB - 45 Hz / 7 kHz
By buying this product you get 123 loyalty points
Reference : 40
1 239,00 €tax incl.
1 032,50 € tax excl.
Based on the 285 GMF, we adopted the same engine as the 215-2000. This allows us to get a serious even faster.
With a lower Qt and higher efficiency, it is the ideal medium low in multichannel active installations.
In the plane panel it can accompany a 215-2000 and it is the ideal engine for a bass lodge.
Sensitivity 1 W / 1m to Fs101 dBfs45 Hz
Bandwidth45 to 7kHzRe6.5 ohms
Impedance8 ohmsqt0.2
Power consumption RMS70 WQe 0.22
Weight7.5 kgQm6
Suspension3-ply paperVas200 L
Linear Excursion8 mmbl12
Alnico Magnet3.5 kgcms0.6
Magnetic field 2.1 T mms18.5g
HP Diameter290 / 307mmsd
471 cm²
Speaker Power (W RMS)70
Speaker TypeMidbass
Impédance8
Diamétre Haut Parleur (cm)280
Rendement101
Xmax8
Lowest frequency45
Highest frequency7000
Colissimo - TNT - SoColissimo
