MONACOR SPH-10M Hi-Fi Bass Speaker 25.5cm 200W 8Ω
MONACOR SPH-10M Haut-parleur de grave Hi-Fi 25.5cm
5785
129,00 €tax incl.
107,50 € tax excl.
MONACOR SPH-10M Hi-Fi speaker 200 WMAX 8 Ω
  • Grave Hi-Fi with long travel, excellent quality of realization
  • Deep bass reproduction
  • Damped polypropylene membrane, low in resonance
  • Solid aluminum bowl, 8-hole screw connection
  • Magnetic system with drilling of pole pieces and pole plate
  • Ideal for bass-reflex, TML and closed loudspeakers
Features:p>Impedance (Z): 8 Ω
Resonant frequency (fs): 29 Hz
Maximum bandwidth: f3-2000 Hz
Maximum power: 200 WMAX
Nominal power (P): 120 WRMS
Average sound pressure (1 W / 1 m): 89 dB
Compliance susp. (Cms): 0.41 mm / N
Weight (Mms): 69 g
Mechanical overvoltage. (Qms): 2.62
Electrical overvoltage (Qes): 0.60
Fact. total surge (Qts): 0.49
Volume equ. (VAS): 73.5 l
DC resistance. (Re): 6.5 Ω
Force factor (BxL): 11.5 Tm
Coil Inductor (Le): 1.1 mH
Coil diameter: Ø 50 mm
Coil Holder: Aluminum
Linear excursion (X MAX): ± 6.25 mm
Transmitting surface (Sd): 363 cm 2
Weight: 1.1 kg
Weight: 3.85 kg
https://www.audiophonics.fr/images2/5785/5785_SPH-10M.jpg
https://www.audiophonics.fr/images2/5785/5785_SPH-10M_1.jpg
https://www.audiophonics.fr/images2/5785/5785_SPH-10M_2.jpg
Colissimo - TNT - SoColissimo
