Monacor SPH-250KE
Monacor SPH-250KE
854
132,20 €tax incl.
110,17 € tax excl.
Hi-Fi bass speaker, 150 W MAX , 8 Ω
Kevlar fiber diaphragm, molded aluminum bowl, long stroke, for 3-way systems, close or bass-reflex. For all types of Hi-Fi and high-end uses.
Impedance (Z)
8 Ω
Resonance frequency (fs)
23 Hz
Maximum bandwidth
f3-3000 Hz
Maximum power
150 W MAX
Rated power (P)
100 W RMS
Average sound pressure (1 W / 1 m)
90 dB
Compliance susp. (Cms)
0.94 mm / N
Moving mass (Mms)
45 g
Mechanical overvoltage. (Qms)
5.25
blank.gif </ Font>
Electrical overvoltage (Qes)
0.45
Fact. total surge (Qts)
041
Volume equ. (VAS)
204 l
DC resistance. (Re)
6.1 Ω
Force factor (BxL)
9.4 Tm
Inductance coil (The)
0.7 mH
Coil diameter
blank.gif </ Font>
50 mm
Coil holder
Kapton
Linear Excursion (X MAX )
± 4.75 mm
Transmitting surface (Sd)
346 cm 2
Magnet Weight
29.5 + 1.76 oz.
Weight
3 kg
PDF-Download
Colissimo - TNT - SoColissimo
