Pas d’amélioration sonore à mes oreilles par rapport au combo audiopro link 1 + DAC project head box digital. Donc renvoyé. Sinon appareil semblant solide, bonnes finitions, appli intuitive
By buying this product you get 54 loyalty points
Multiroom Streamer WiFi Bluetooth 5.0 24bit 192kHz MQA Black
The BlueSound Node 3 opens up the world of remote control, network playback, streaming and multi-room. Easily integrated into an existing HiFi system, it will allow you to upgrade your audio setup with new features.
The BlueSound Node 3 works as an extremely versatile network player with WiFi, Ethernet and Bluetooth 5.0 connectivity, allowing you to remotely control your music playback from your local network, your favorite streaming app or internet radio once integrated into your audio system. Remote control is simply done via the BluOS application, available on iOS, Android, Windows or Mac.
If it is compact, the BlueSound Node 3 is nevertheless a real concentrate of technologies. Underneath its casing is an audiophile digital-to-analog converter that supports not only PCM streams up to 24bit 192kHz, but also MQA for superior listening. With software features such as tone control and the ability to use a fixed level output, you can customize your listening preferences in detail.
Particularly versatile, the Node 3 can connect via HDMI eARC, WiFi, Bluetooth or host a USB storage device. It also supports AirPlay 2 and Spotify Connect protocols, and is compatible with the Bluetooth aptX HD codec. As a result, the BlueSound Node 3 offers a wide range of integration possibilities within an existing system, adapting to any situation with ease.
The Node 3, with its BluOS application, allows you to simply and remotely control all your connected players. BluOS is currently the only platform capable of supporting up to 64 players while broadcasting at 24bit. In addition, it provides access to a wide range of features and services to suit everyone's needs and desires.
The Node 3 incorporates a touch-sensitive surface on the top for accessing the device's basic functions, such as controlling playback or volume level. The Node 3 can also be controlled using a voice assistant such as Siri, Alexa or Google Voice, or even by programming your own IR remote. Advanced controls like tone control or subwoofer crossover optimization are available directly from the BluOS Controller app. Finally, the BlueSound Node 3 can also be connected to Lutron, Elan, RTI, Crestron and other home automation systems.
One of the Node 3's assets is the ease with which it can be used to set up a connected and fully remote-controlled multi-room system. This means you can broadcast your music throughout your home, synchronized or not, with settings easily made from the BluOS interface.
Product type | Streamer |
Connectivity | WiFi 5 (802.11ac, 2.4/5GHz) Ethernet RJ45, GigE 1000Mbps Bluetooth 5.0 bidirectional |
Audio inputs | 1x Combo Mini-Toslink / Jack 3.5mm 1x HDMI eARC |
Audio outputs | 1x Analog stereo RCA (fixe or variable level) 1x Coaxial 1x Optical Toslink 1x USB-A 2.0 (USB Host) 1x Jack 3.5mm headphone output 1x Subwoofer output (RCA) (network coupling to Pulse Sub+.) |
Trigger | 12V |
IR Remote control | Included IR Jack 3.5mm input |
Supported file formats | MP3, AAC, WMA, WMA-L, OGG, ALAC, OPUS, WAV, AIFF, MPEG-4 SLS, MQA |
CPU | ARM Cortex-A53 Quad Core, 1.8GHz par coeur |
Native sampling rates | 16-24bit 192kHz |
SNR | -113dBA |
THD+N | 0.002% |
DAC | NC |
OS | BluOS |
Compatible OS | iOS Android Windows Vista, 7, 8, 10 Mac OS 10-11 |
Straming services | Deezer, Deezer HiFi, Spotify, Qobuz, Tidal, Napstrer, Amazon Music, Web radios... |
Others transmission protocols | AirPlay 2 Spotify Connect Tidal Connect Roon Ready |
Voice control | Amazon Alexa Skills Actions on Google |
Control systems | Control4 Crestron URC RTI ELAN Lutron |
Power supply | 100-240VAC (cable included) |
Dimensions | 220 x 146 x 46mm |
Weight | 1.09kg |
Package | 1x Bluesound Node 3 1x Power cable 1x Ethernet cable 1x Stereo RCA cable 1x Toslink to Mini-Toslink adapter |
Input | Jack 3.5mm |
Input | RJ45 |
Input | WiFi |
Input | Bluetooth |
Input | HDMI |
Input | Optical Mini-Toslink |
Output | Optical Toslink |
Output | Jack 3.5mm |
Output | Bluetooth |
Output | USB |
Output | RCA |
Output | Subwoofer |
Output | WiFi |
DAC / ADC Chip | NC |
Max sampling rate | 192kHz |
Color | Black |
Remote Control | No |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Average votes 4.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Bouexiere c.
Pierre T.
