All working well. High level sound. Cleaver gadget.
By buying this product you get 59 loyalty points
Android Drive Streamer I2S USB SPDIF AES 32bit 768kHz DSD512
The JF Digital MX-1Pro is a high-end streamer at a low price that will allow you to enjoy all your audio files stored locally or on your network. It is based on an Android 7.0 operating system that allows you to install the applications of your choice on the player in order to enjoy a fully customized use adapted to your needs. Its front panel is covered with a large and beautiful 8" touch screen allowing easy reading of information and simplified configuration of the device.
A 4 core processor, 2GB of DDR3 RAM and 64GB of eMMC ensure fast data processing for smooth operation. The MX-1Pro's well-thought-out architecture allows it to read high-resolution files, up to PCM 32bit 384kHz and DSD512. Its low phase noise clocks allow it to significantly reduce jitter and its regulated power supply provides a signal specific to all the reader's circuits. This careful design allows the MX-Pro to offer a precise, detailed and rich reproduction.
The Pro version of the JF Digital MX does not have an integrated DAC. It is intended to be versatile and thus allows you to associate it with the external DAC that will suit you best.
The MX-1Pro offers several control options. Of course, its 8-inch touch screen allows easy access to all the device's features. Since the device uses Android, its use is very similar to what can be found on a smartphone with the same OS.
This beautiful screen that will allow you to navigate through the many features of the device also allows you to display video, metadata of your audio files (sampling rate, titles, album artwork, etc.) as well as all playback information (volume, playback mode, playlists...).
It is also possible to control the player using the supplied IR remote control. This very complete one allows you to access a large number of features of the MX-1Pro without having to get up from your sofa.
Versatile, the MX-1Pro has a wide connectivity to meet most needs. On the wireless or network side, the device offers WiFi 2.4G/5Gand an RJ45 port for 100Mbps/1Gbps Ethernet. A supplied antenna significantly improves wireless reception of WiFi. A USB-A input is also available to connect a storage device such as a hard disk or USB stick, as well as a Micro SD port.
For the outputs the MX-1Pro has a second USB-A connector with an XMOS interface to connect an external DAC, as well as an I2S HDMI LVDS, Coaxial, Optical and finally a balanced AES output on XLR connector.
The embedded Android operating system, while allowing audio playback, is also able to play video files easily. Simply use the video playback application provided to immediately enjoy an audio/video playback solution.
I2S LVDS output compatible with I2S Audio-GD / PS Audio.
Specifications | ||
Product type | Streamer | |
OS | Android 7.1 + Custom Audio Framework | |
CPU | 4 Cores | |
RAM | 2Go DDR3 | |
ROM | eMMC 64Go | |
Screen | 8" | |
Inputs | 1x USB-A XMOS OTG (Hard drive up to 8TB) 1x Micro SD up to 256Go WiFi 2.4G/5.8G RJ45 | |
Outputs | 1x USB-A 1x Coaxial 1x Optical 1x AES/EBU 1x I2S LVDS HDMI | |
Supported sampling rate | USB : PCM up to 32bit 384kHz, DSD up to DSD512, DoP up to DoP128 Coaxial, Optical, AES/EBU : PCM up to 24bit 192kHz, DoP64 I2S : PCM up to 32bit 384kHz, DSD up to DSD256, DoP up to DoP128 | |
Supported protocols | DLNA Samba | |
Supported formats | DSF, DFF, DSR, ISO, WAV, APE (Fast/High/Normal), AIFF, MP3, FLAC, WMA, AAC | |
Output level | 2Vrms | |
Frequency response | 10Hz-40kHz (+/-1dB) | |
THD+N | <= 0.002% | |
SNR | >115dB | |
Dynamic range | >120dB |
General | ||
Color | Black | |
Dimensions | 220 x 250 x 76mm | |
Weight | 4.5kg | |
Package | 1x JF Digital MX-Pro 1x Power cable 1x USB Cable 1x Antenna 1x Remote control (AAA Batteries sold separately) |
Input | Micro SD |
Input | WiFi |
Input | RJ45 |
Output | I2S LVDS via HDMI |
Output | Coaxial SPDIF |
Output | Optical Toslink |
Output | XLR |
Output | Bluetooth |
Max sampling rate | 384kHz |
Max sampling rate | DSD512 |
Color | Black |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Libor K.
Mesmer B.
