ROSE HIFI RS150B Streamer DAC SABRE ES9038PRO 32bit 768kHz DSD512 MQA Bluetooth WiFi DLNA AirPlay Silver
ROSE RS150 Media Center DAC AK4499EQ 32bit 768kHz DSD512 MQA Bluetooth WiFi DLNA AirPlay
Rose's RS150 is a high-performance network player and media center, offering a wide range of multimedia services as well as exceptional sound quality and support for ultra high-resolution video.
By buying this product you get 449 loyalty points
Reference : 15364
4 490,00 €tax incl.
3 741,67 € tax excl.
Shipping from France
Billing in France
Technical support in France
Rose RS150
Media Center DAC ES9038PRO 32bit 768kHz DSD512 MQA Bluetooth WiFi DLNA AirPlay Silver
Rose RS150 Media Center DAC AK4499EQ 32bit 768kHz DSD512 MQA Bluetooth WiFi DLNA AirPlay
Rose's RS150B is a high-performance network player and media center, offering a wide range of multimedia services as well as exceptional sound quality and support for ultra high-resolution video.
A flawless conversion stage
The digital/analogue conversion stage incorporates the excellent Sabre ES9038PRO DAC chip. This supports high resolution files up to 32bit 768kHz PCM and up to DSD 512 (Native). In addition, taking advantage of the proprietary Velvet Sound technology, this chip provides excellent measurements with a low noise level, for an exceptionally rich and dense sound reproduction.
The entire unit has been calibrated and adjusted by experienced acoustic engineers for perfect reproduction across the entire audio spectrum, from deep, intense lows to elegant highs.
Optimized linear power supply
The linear power supply stage of the Rose RS150 benefits from an intelligent design to significantly reduce electrical noise in order to provide the various circuits with a clean electrical signal for distortion-free sound reproduction.
High Precision Femto Clock
The RS150 also features a high-precision femtosecond clock, drastically limiting distortion while providing a wide and accurate sound image.
Solid Aluminium frame
All the components of the RS150 are concealed under a magnificent high-purity solid aluminium chassis, which promotes efficient heat dissipation. The number of parts in this chassis is also considerably limited in order to limit the impact of vibrations that could alter sound reproduction.
MQA Certification
Rose's Media Center supports Master Quality Authenticated (MQA) technology through an integrated decoder. This award-winning British technology delivers the sound of the original master recording. The file is authenticated by the record company, artist or rights holders. In addition, this type of file is light enough to be streamed.
UHD 4K video support
The RS150 also allows you to enjoy Ultra HD 4K video, stored locally or via the Rose Tube application, thanks to its HDMI output. Ideal for a Home Theater system!
A large 14.9" touch screen
The front of the device features a beautiful, large 14.9" IPS touch screen for intuitive navigation through the RS150's ergonomic interface.
Rose Connect App & Bluetooth Remote Control
The Rose RS150 can therefore be controlled not only via its touch screen, but also with the dedicated Rose Connect application, available free of charge on Android and iOS devices. This allows you to play your music and videos locally or from a network location.
The device can also be controlled using the supplied Bluetooth remote control, which is particularly convenient for operating the device directly from the sofa.
Application Rose Connect Android
Application Rose Connect iOS
Rose OS: an innovative system
The RS150 features the Rose OS operating system, enabling an innovative music experience. It allows you to stream and play your music in ultra high quality, enjoy support for 4K videos, a commercial-free YouTube application, as well as many radio stations, manage CD playback and burning (via an external drive) and much more!
Connectivity
The RS150 allows you to stream your audio or video files very simply. The device supports AirPlay and DLNA protocols and allows you to connect smartphones, tablets and computers via WiFi, Ethernet or Bluetooth.
In addition, its rear panel offers a particularly complete panel of connectors, which will meet the vast majority of needs for integration into all audio / video systems.
Rose RS150 Media Center DAC AK4499EQ 32bit 768kHz DSD512 MQA Bluetooth WiFi DLNA AirPlay Rose RS150 Media Center DAC AK4499EQ 32bit 768kHz DSD512 MQA Bluetooth WiFi DLNA AirPlay
A media library at your disposal
Designed to hold sufficient storage for your HiFi audio files, the RS150 is compatible with SSDs up to 4TB, external HDDs up to 10TB or Micro SD cards up to 400GB. It also allows the connection with a NAS.
Product typeMedia Center
Audio inputs1x Coaxial SPDIF
1x Optical Toslink
1x AES/EBU
1x USB-B 2.0
1x HDMI ARC
1x Line stereo RCA input
Audio outputs1x Pre-Out Single-ended stereo RCA
1x Pre-Out Balanced XLR
1x Coaxial SPDIF
1x Optical Toslink
1x AES/EBU
1x I2S via DVI
1x I2S via RJ45
Video output1x HDMI 2.0 (up to 3840 x 2160px / 60Hz)
Network connectivityEthernet RJ45 10/100/1000 BASE-T
WiFi via USB dongle (sold separately)
Bluetooth connectivityBluetooth via USB dongle (A2DP Sink, AVRCP v1.3) (sold separately)
Media connectionFile system: SMBv1, SMBv2 / FTP / WebDav / NTFS / eXfat / FAT32
Connectors : 2x USB-A 3.0, 1x Micro SD, 1x SSD
Supported streaming protocolsAirPlay
DLNA
Roon Ready
MQA Full Decoder
Supported streaming servicesTIDAL
Radio internet
Podcast
Supported audio codecsWAV, FLAC, AIFF, WMA, MP3, OGG, APE, DFF, DSF, AAC, CDA, AMR, APE, EC3, E-EC3, MID, MPL, MP2, MPC, MPGA, M4A
PCM up to 32bit 384kHz
Native DSD up to DSD512
Supported video codecsASF, AVI, MKV, MP4, WMV, MPEG-1, MPEG-2, MPEG-4 H.263, H.264, H.265, VC-1, VP9, VP8, MVC
H.264/AVC, Base/Main/High/High10 profile @ level 5.1 up to 4Kx2K @ 30fps
H.265/HEVC, Main/Main10 profile @ level 5.1 High-tier up to 4Kx2K @ 60fps
OSRose OS V1.22.4 (base on a custom version of Android 7.1)
CPUHexa Core CPU
Dual Core Cortex-A72 up to 1.8GHz
Quad-Core Cortex-A53 up to 1.4GHz
GPUMali-T864
OpenGL ES 1.1/2.0/3.0/3.1
OpenVG1.1
OpenCL
DX11
RAMLPDDR3 4GByte
DAC chipSabre ES9038PRO
Supported sampling ratesPCM up to 32bit 768kHz
DAC TechnologyVelvet Sound
THD+N DAC-124dB
Dynamic range DAC134dB
SNR DAC134dB
Output levelSingle-ended : 4.5Vrms
Balanced : 9Vrms (no load)
SNRSingle-ended : 117dB @1kHz
Balanced : 120dB @ 1kHz
THD+NSingle-ended : 0.0005% @ 1kHz
Balanced : 0.0003% @ 1kHz
THDSingle-ended : 0.0003% @ 1kHz
Balanced : 0.0002% @ 1kHz
Software updateVia internet
Via USB OTA
Via Rose Store
Remote controlBluetooth remote control
Rose Connect app (Android, iOS)
Supply voltageAC 100-230V 50/60Hz
Input power55W
FuseT3.0AL/250V
Dimensions430 x 316 x 123mm
Weight13kg
Case materialDesigned in a solid block of high purity aluminium, minimizing vibrations.
ColorSilver
Package1x Rose RS150B
1x Power cable
1x Bluetooth remote control
4x SSD Screws
InputHDMI
InputAES/EBU
InputRJ45
InputWiFi
OutputWiFi
OutputOptical Toslink
OutputI2S via RJ45
OutputHDMI
OutputBluetooth
OutputAES/EBU
OutputI2S via DVI
OutputCoaxial SPDIF
OutputRJ45
DAC / ADC ChipAK4499
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlYes
Streaming services & Network protocolsTidal
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsWeb radios
Rose's RS150 is a high-performance network player and media center, offering a wide range of multimedia services as well as exceptional sound...
