VIBRAPOD ISOLATORS MODEL5 Insulator / Vibration Absorbers (Set x4)
VIBRAPOD ISOLATORS MODEL5 Isolateur/Absorbeur Vibrations (Set x4)
Reference : 2655
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Vibrapod absorbers
Set (x4)
Vibrapod isolators (or absorbers) are designed to absorb vibrations that could be transmitted to your Hifi and video devices or other...
They protect devices from vibrations that degrade sound or video quality.
Because an absorber suitable for a 5kg CD player will not work for a 40kg amplifier, Vibrapod has designed 5 models in order to obtain optimal operation regardless of the weight of the device.
These are surely the absorbers that have the best efficiency/price ratio.
Your ears will certainly thank you...
There are 5 models of Vibrapods depending on the weight of your components:
Vibrapod modelRecommended weight
(kg per Vibrapod)
Minimum - maximum weight
(kg per Vibrapod)
Min - max device weight
for 4x Vibrapods
Model #11.10.90 - 1.363.6 - 5.4
Model #22.71.81 - 3.627.2 - 14.4
Model #34.53.62 - 5.4414.4 - 21.7
Model #47.26.35 - 8.1625.4 - 32.6
Model #511.39.9 - 12.739.8 - 50.8
Dimensions: 1.5cm high x 6.2cm in diameter.
For devices with feet with a diameter greater than 4.2cm, it is possible to place them directly on the dome of the Vibrapod
For devices with feet with a diameter between 1.9 and 4cm, they must be placed on the central island, Vibrapod upside down (photo2)
For devices on spikes, a tailstock with a minimum diameter of 1.9cm must be added.
In some cases, when the bottom of the device is uneven, the original feet are too small or the device heats up, it is advisable to use a "sandwich" assembly
You must then place your device on a shelf, which itself will rest on Vibrapods.
Remember to include the weight of the shelf when choosing the model of Vibrapods.
Due to their vinyl design, it is possible that the Vibrapods leave some marks on smooth surfaces.
Diameter (mm)62.0
MaterialRubber
Height15.0
Etonnant
Acheté pour remplacer des pieds temporaire sous des enceintes de 45kg piece. Deja la qualité du produit est bonne, c’est plutot simple mais bien fait. Et sur ces enceintes, il y a eu de legers changements dans le son. Un peu plus de basse et des mediums moins fouillis. Les pieds precedents étaient des monacor caoutchouc mais en surcharge. Au moins pour des enceintes je conseille vivement a ce prix.
This review has been posted for VIBRAPOD ISOLATORS MODEL5 Insulator / Vibration Absorbers (Set x4)
