FURUTECH e-TP80E 8-Port Power Filter + FURUTECH G-314Ag-18E
Furutech e-TP80E Filtre secteur 8 ports
By buying this product you get 126 loyalty points
639,00 €tax incl.
532,50 € tax excl.
The e-TP80E is luxurious and sophisticated, it is a power distributor that eliminates common problems encountered with audio-video components and caused by polluted electrical current.
The waveform of the alternating current becomes severely twisted by various sounds, peaks of tension and sagging.
There are also devices that deform above and below the waveform of the current.
In addition, you are never alone; your residence shares with other apartments, houses, and businesses the same transformer.
That's why users who are keen on Audio and Video note that their systems are nicer at night or on weekends!
The AC waveform is severely distorted by voltage spikes, high frequencies, noise from other components of your own system, and high-frequency radiation from digital processors and interconnects.
The built-in phase tester is used to check that the phase is respected between the mains plug and the filter.
The special design of the aluminum chassis effectively protects against another common problem, RFI (Radio Frequency Interference)
Internal wiring is made from a FURUTECH μ-14 wire (14 AWG) wire which guarantees a low resistance.
The contacts of the Schuko and the connectorseur IEC input are phosphor bronze gold-plated 24k
Characteristics :
  • Supply voltage: 250V 50 / 60Hz
  • Supported Current: 10A
  • Maximum power. 2500 W
  • 8 bases SHUCKO Furutech Gold plated
  • Insulated internal wiring Teflon.
  • Automatic Circuit Breaker Protection
  • Supplied with mains cable FURUTECH G-314Ag-18E (1.8m)
More Info HERE
Review of the magazinePicture and sound :
Colissimo - TNT - SoColissimo
