ETI Regular PhonoPod Tellurium RCA Headers 75ohms (Pair)
ETI Regular PhonoPod Embases RCA Tellurium 75ohms (la paire)
Reference : 6783
59,00 €tax incl.
49,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
The PhonoPod®> RCA sockets offer unlike most of their competitors, even those marketed as high-end significantly increased conductivity.
The vast majority of the bases are made from nickel, golden brass or bronze / phosphorus alloy with a conductivity typically less than 28% IACS (International Annealed Copper Standard).
By way of comparison, the high purity copper used in the vast majority of interconnecting cables has a conductivity rating of 100% IACS. Due to this low conductivity and the use of three disparate metals, the majority of standard RCAs, even expensive tend to decrease the performance of the components to which they connect.
The ETI approach is radically different, the contact elements are machined in high purity Copper Telurium (more than 90% IACS) so as to ensure maximum conductivity (this allowing a gain of up to 320%).
Characteristics :
  • Packing: 1 pair
  • 75 ohms for digital use (S / PDIF)
  • Contact Material: Copper Tellurium (CuTe)
  • Gold plating 20 micron directly applied to copper (no nickel, bronze or brass)
  • Spacing: 3mm
  • Max. : 15mm
  • Length: 18mm
PDF Manufacturer
s-content "class =" almost_half_cell ">
[Img-11230-left-large_default]
[Img-11231-left-large_default]
Detail of contact elements
https://www.audiophonics.fr/images2/6783/6783_ETIPHONOPODRCA_2.jpg
Mounting typeTo weld
Max panel thickness (mm)3.0
