Refurbished product - Grade S
Brand new product. Packaging: 7 bases with red ring, 1 base with black ring
Female Banana Plug Gold Plated Ø3.8mm (7 Red / 1 Black)
These sockets will allow you to connect your banana plugs directly to the output of your HI-FI equipment.
Product type | Banana plug sockets |
Max cable diameter | Ø3.8mm |
Length | 25mm |
Width | 11mm |
Max panel thickness | 11mm |
Insulating ring diameter | Ø10.5mm |
Plating | Gold |
Weight | 12g/unité |
Quantity | 7 Connectors with red ring 1 Connector with black ring |
Mounting type | To screw |
Connectic | Female |
Max panel thickness (mm) | 11.0 |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Refurbished Grade | Grade S |
