Refurbished product - Grade A
Cardboard box slightly damaged.
Balanced ES9038PRO DAC CPLD Altera XMOS 32bit 768kHz DSD512 Black
The D1se from SMSL is an extremely powerful DAC, based on a symmetrical architecture using a high-end ESS ES9038Pro digital to analog conversion chip. Taking advantage of a flawless design, it will satisfy the most demanding audiophiles.
The SMSL D1se is able to decode MQA (Master Quality Authenticated) audio files. These are the guarantee of a restitution quality as close as possible to the original studio recording for an incomparable listening.
The D1se uses an ESS ES9038Pro DAC chip for its conversion stage. This one offers incredible sound performances and excellent measurements, with notably a SNR of 140dB and a THD+N of -122dB. In addition, this 32bit 8-channel chip ensures a very low distortion of 0.00009% (-121dB) and supports high-resolution audio streams up to PCM 32bit 768kHz and DSD512.
All the circuits of the D1se also benefit from high-end components. We find an ES9311 chip in the power supply stage, allowing to provide the DAC with a low noise electrical signal. This power supply stage also embeds Nichicon KG filtering capacitors as well as a high quality Noratel toroidal transformer. An XMOS XU-216 32bit USB interface is also used to process USB streams quickly and efficiently.
The SMSL D1se embeds a Bluetooth 5.0 receiver and an antenna, allowing you to remotely broadcast your music, directly from your smartphone. Moreover, it supports the aptX codec, ensuring a fast and stable transmission for a quality of restitution close to that of the CD.
1 | Screen |
2 | IR Receiver |
3 | Input selection button |
4 | Bluetooth button |
5 | Standby LED |
6 | Function button |
7 | Single-ended line output |
8 | Bluetooth antenna |
9 | Optical input |
10 | Balanced line output |
11 | I2S input |
12 | Coaxial input |
13 | USB input |
14 | Power connector (100-240VAC) |
Product type | DAC |
DAC Chip | ESS ES9038Pro |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial 1x I2S via HDMI Bluetooth |
Outputs | 1x Single-ended RCA 1x Balanced XLR |
THD+N | 0.00009% (-121dB) |
Dynamic range | XLR : 130dB RCA : 123dB |
SNR | 130dB |
Output impedance | XLR : 207Ω RCA : 142Ω |
USB Transmission | Asynchronous |
USB Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX Linux |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 Optical / Coaxial : PCM up to 24bit 192kHz, DSD64 (DoP) |
Bluetooth version | 5.0 |
Bluetooth codecs | AAC, SBC, aptX |
Consumption | 5W |
Standby consumption | <0.5W |
Housing material | Aluminum |
Dimensions | 210 x 39 x 185mm |
Weight | 1.64kg |
Color | Black |
Package | 1x D1SE Black 1x Bluetooth antenna 1x Remote 1x Schuko power cable |
Input | I2S via HDMI |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Output | XLR |
Output | RCA |
DAC / ADC Chip | ES9038PRO |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Networking | No |
Remote Control | Yes |
Refurbished Grade | Grade A |
