MATRIX M-STAGE HPA-3U+ USB DAC Headphone Amplifier Class A 24bit 192kHz DSD128
MATRIX M-STAGE HPA-3U+ Class A Balanced Headphone Amplifier
The Matrix M-Stage HPA-3U+ is an evolution of the brand's famous Class A amplifier with an audio converter and USB input. This amplifier has been completely redesigned and optimized to offer even more music to the experienced enthusiast.
By buying this product you get 36 loyalty points
Reference : 11643
365,83 €tax excl.
Including 0,04 € for green tax
Matrix M-Stage HPA-3U+ DAC USB Amplificateur Casque Class A DSD
With a selection of gain on the front over three levels, you benefit from a perfect impedance matching on any top-of-the-range sedentary headset. Many technological points have been improved, making this USB headset amplifier even more attractive:
  • New Aluminium chassis design
  • 4 Transistors per polarized side Class A with shorter circuit
  • Parallel circuit improving crosstalk
  • Lower output impedance (Line output 2Ω / Headphone output 0.2Ω)
  • Extended Dynamics (112dB)
  • Potentiometer ALPS RK27 Serie
  • WIMA and Nichicon audiophile quality capacitors
  • Non-inductive film resistors
  • Noratel toroidal transformer with antistatic screen and low radiation
This USB DAC preamplifier is the ally of high-end headphones, including the AKG 702 and Beyerdynamic series. It will bring finesse, dynamism and a very attractive balance.
AUSB Input 24bit 192kHz
BStereo RCA input
CStereo RCA output
DON/OFF button
EPower supply connector
AJack 6.35mm headphone output
BPower status LED
CInput selector
DGain selector (5dB / 10dB / 20dB)
EVolume button
FDSD State LED
Qobuzissime for the Matrix M-Stage HPA-3U
" The headphone amplifier with DAC M-Stage HPA-3U is a very nice device, which has a big mouth and looks indestructible. Using high quality components, it offers first-class sound quality and is full of power. "
Qobuzissime pour le Matrix M-Stage HPA-3U
Matrix M-Stage review by Audio Science Review
Overall, I recommend the HPA-3U as a strong headphone amplifier "
Test du Matrix M-Stage par Audio Science Review
Inputs1x USB-A
1x Single-ended Stereo RCA
Outputs1x Jack 6.35mm
Gain setting5dB
10dB
20dB
USB interface chipXMOS U8
USB TransmissionAsynchronous
Supported sampling rateUSB : PCM up to 24bit 192kHz / DSD up to DSD128 (DoP and native ASIO)
OS CompatibilityWindows XP / Vista / 7 / 8 / 8.1 / 10 (needed driver included)
MAC OSX 10.6.4 or later
Android (with OTG compatibility)
iOS (with Camera USB adapter)
RCA Line Output Measurements
SNR> -112dB Class A
THD+N< 0.0003% @ 1kHz
Frequency response20Hz - 20kHz (+0.01dB / -0.04dB)
Output impedance51Ω
Power output (@ THD+N = 0.01%)2800mW @ 33Ω
420mW @ 300Ω
210mW @ 600Ω
Jack 6.35mm headphone output measurements
SNR> -112dB Class A
THD< 0.0003% @ 33Ω, 325mW, 1kHz, Class A
Frequency response20Hz - 20kHz (+0.03dB / -0.1dB)
Output impedance0.2Ω
Output power (@ THD+N = 0.01%)2100mW @ 33Ω
430mW @ 300Ω
220mW @ 600Ω
Consumption< 25W
FuseAC250V / 500mA 5x20mm
Dimensions285 x 142 x 49mm
Weight1.7kg
Package1x Matrix M-Stage HPA-3U+
1x Power cable
1x USB cable
InputUSB 2.0
InputUSB XMOS
InputUSB-B
OutputJack 6.35mm
Max sampling rate192kHz
Max sampling rateDSD128
Components / ChipCS4398
ConnectionTo connect
StructureAluminium
Channel2 channels (Stereo)
ClassClass A / AB
Colissimo - TNT - SoColissimo
The Matrix M-Stage HPA-3U+ is an evolution of the brand's famous Class A amplifier with an audio converter and USB input. This amplifier has...
