SBC 1.5Ghz CPU - 3GB RAM - Wi-Fi / LAN / Bluetooth / USB-C
Caution, to use the VIM with its dedicated DAC, please make sure you chose the VIM version Tone Board.
The VIM2 is a complete SBC with high-performance boarding circuits and components. It has modern connectivity and a wide pannel of inputs / outputs.
With its 32Gb of eMMC memory, its T820MP3 GPU , its large RAM and with its HDMI output supporting 4K, SBC VIM2 is entirely appropriate for multimedia use, highly diversified uses, audio, video, media server, stream A / V platform video games etc ...
It is based on a Cortex-A53 processor 1.5GHz 64bit Octa Core ARM, RAM 3GB in DDR4 and graphics unit 750MHz ARM Mali-T820MP3 GPU, the VIM2 clearly announced his intention to stand out from its competitors by its power and speed calculations. Its performance and connectivity developed make it an ideal base for a high-precision music player & high definition.
Many accessories available - starting with the excellent DAC Khadas ToneBoard - can exploit its performance and its extensive connectivity for purely audiophiles uses.
The is an obvious choice for all audio players construction projects, streamers, advanced multimedia platforms and able to function together, are included with high-end audio equipment.
Any decent SBC must show flexibility in order to accommodate a variety of uses. In this context, the connectivity is a decisive factor on which the VIM2 obviously does not deadlocked.
Physical connections include two USB 2 ports A Female allowing SBC to communicate with most of the access or storage devices on the market. In the case of a media platform, it will allow ajoindre there extrerne a hard drive or USB-key to access its files quickly. The USB ports respectively support a load of 900mA and 500mA (as much as a high-end notebook computer).
The VIM2 has a TF card reader supports up to 128Gb.
It also includes a Gigabit LAN interface 10/100 / 1000Mbps. This interface is accompanied by a carrier WoL (Wake on Lan) allowing the powering of the remote device via the network. This ability will prove very interesting Solicitating for the establishment of deportees systems, redundant, multi-room or remote controlled.
A GPIO greatly increases the possibilities of the card. Of the 40-pin, 10 allow to communicate with the I2S DAC ToneBoard card. This port mainly opens the door to specific developments in an advanced audio & computing environment.
A female HDMI type A compliant 4K @ 60Hz performs video output functions / primary display. The SBC has therefore natively modern video output
Finally the main power through a USB port-C. The VIM2 therefore take comfort, robustness and load speed associated with this technology. If this port is not used for charging, it also makes data port office with OTG support.
Side wireless connectivity, VIM2 is equipped with a WiFi chip 2x2 MIMO 802.11ac and a Bluetooth 4.2 support. The card also has an infra-red receiver to enable remote control.
Warning: only the VIM2 is delivered
According to the uses , SBC VIM2 can accommodate accessories specially designed to increase performance and accessibility.
For tasks requiring significant computing power, a heat sink and a fan can be mounted directly on the map. Note that it is possible to mount only the passive heatsink if VIM2 must meet the audio features do not tolerate noise.
A remote control I / R two channels can control the remote card.
To provide a solid and professional finish to VIM2, a specially designed housing is available.
Finally, the DAC ToneBoard - recognized as one of the best D / A converters on the market do it yourself - and whose design carefully respects the form-factor and integration of VIM2 VIM will transform the map into a real player audiophile network with high-fidelity DAC.
The VIM2 is capable of running many different operating systems based on the use you book it.
It is possible to install Android 7.1, Google Fuchsia, Linux Main, Libreelec 8.9 and later, Ubuntu 16.04 and newer.
Package Contents | |
Type | SBC (Single Board Computer) |
CPU | Amlogic S912 Octa Core 1.5GHz 64bit ARM Cortex-A53 |
RAM | 3GB DDR4 |
GPU | Unit Graphic: 750MHz ARM Mali GPU-T820MP3 Decoder: HW UHD H.265 / VP9 60fps 10bit Processor: HLG HDR10 and HDR |
eMMC | 32GB |
Wireless | AP6359SA 802.11b / g / n / ac 2X2 MIMO |
Bluetooth | v4.2 |
Ethernet | 10/100 / 1000Mbps |
WOL | supported |
I / R | Receiver 2ch |
inputs | USB OTG-C USB-A TF Player RJ45 Wireless Bluetooth GPIO |
Outputs | HDMI x1 |
Power supply | 5-9V DC (5 recommended) |
GPIO | Pins 40 2.54mm Pitch / USB, I2C, I2S, SPDIF, UART, PWM, ADC, 7816, IOs |
Buttons | x3 (Power, Func, Reset) |
Mounting Holes | M2 x4 |
Dimensions | 82.0 x 57.5 x 11.5 mm |
VIM2 PCB 1.4 | x1 |
WiFi antenna | x2 |
Input | USB |
Input | Micro SD |
Input | Bluetooth |
Input | RJ45 |
Output | GPIO |
Output | USB |
Output | RJ45 |
Output | HDMI |
Input voltage (V) | 5.0 |
