By buying this product you get 123 loyalty points
Phono Preamplifier RIAA MC ACSS
The Audio-GD LP-1 MC is a high-performance RIAA phono preamplifier, compatible with MC-cell turntables, which offers a careful design that corrects the defects common to many preamplifiers of this type. Here, a low-pass filter (75uS) at the input allows a more linear response between 1kHz and 20kHz.
All of the LP-1 MC's circuitry is designed to provide smooth and accurate sound reproduction. This includes a regenerative power supply, itself composed of 4 Class A PSUs, ACSS circuitry, and quality components such as the 2SK170 FETs in input and output buffers.
The regenerative power supply can block most disturbances from the power line to provide a clean and stable signal to the audio circuits. For this purpose, the LP-1 MC circuitry uses regenerative transformers, Class A power supplies, a wave generator and gain amplifiers. In addition, each audio circuit has its own power supply.
Product type | RIAA Phono preamplifier |
Phono compatibility | MC |
Inputs | 1x Stereo RCA |
Outputs | 1x Stereo RCA 1x Stereo XLR 1x ACSS |
SNR | 80dB |
THD+N | < 0.05% (A-Weighting) |
Frequency response | 20Hz - 20kHz (< -1dB) |
Gain | +60dB @ 1kHz |
Output voltage | 500mV @ 1kHz, 0.5mV |
Output impedance | 10Ω @ RCA > 1kΩ @ ACSS |
Input impedance | 20-600Ω |
Supply voltage | 220-240V AC 50/60Hz |
Consumption | 10W |
Weight | ~5kg |
Dimensions | 240 x 360 x 85mm |
Package | 1x Audio-GD LP-1 MC 1x Power cable |
