AUDIO-GD LP-1HE MC Phono Preamplifier RIAA MM ACSS
The Audio-GD LP-1 MC is a high-performance RIAA phono preamplifier, compatible with MC-cell turntables, which offers a careful design that corrects the defects common to many preamplifiers of this type. Here, a low-pass filter (75uS) at the input allows a more linear response between 1kHz and 20kHz.
By buying this product you get 123 loyalty points
Reference : 15936
1 239,00 €tax incl.
1 032,50 € tax excl.
Audio-GD LP-1HE MC
Phono Preamplifier RIAA MC ACSS
Audio-GD LP-1 MM Préamplificateur Phono RIAA MM ACSS
All of the LP-1 MC's circuitry is designed to provide smooth and accurate sound reproduction. This includes a regenerative power supply, itself composed of 4 Class A PSUs, ACSS circuitry, and quality components such as the 2SK170 FETs in input and output buffers.
Regenerative power supply
The regenerative power supply can block most disturbances from the power line to provide a clean and stable signal to the audio circuits. For this purpose, the LP-1 MC circuitry uses regenerative transformers, Class A power supplies, a wave generator and gain amplifiers. In addition, each audio circuit has its own power supply.
Product typeRIAA Phono preamplifier
Phono compatibilityMC
Inputs1x Stereo RCA
Outputs1x Stereo RCA
1x Stereo XLR
1x ACSS
SNR80dB
THD+N< 0.05% (A-Weighting)
Frequency response20Hz - 20kHz (< -1dB)
Gain+60dB @ 1kHz
Output voltage500mV @ 1kHz, 0.5mV
Output impedance10Ω @ RCA
> 1kΩ @ ACSS
Input impedance20-600Ω
Supply voltage220-240V AC 50/60Hz
Consumption10W
Weight~5kg
Dimensions240 x 360 x 85mm
Package1x Audio-GD LP-1 MC
1x Power cable
Audio-GD LP-1 MM Préamplificateur Phono RIAA MM ACSS Audio-GD LP-1 MM Préamplificateur Phono RIAA MM ACSS
OutputACSS
ClassClass A / AB
The Audio-GD LP-1 MC is a high-performance RIAA phono preamplifier, compatible with MC-cell turntables, which offers a careful design that corrects...
