AVANTREE Saturn Pro AFF Bluetooth 3.0 aptX Low Latency Music Adapter
Avantree Saturn Pro AFF Bluetooth 3.0 Apt-X Low Latency Music Adapter
Reference : 9067
57,90 €tax incl.
48,25 € tax excl.
This small black design works on battery is able to share its dual function of making any audio equipment wireless and has the ability thanks to the technology used to allow wireless transfer of musical streams in CD quality.
By acquiring two of these modules and setting one transmitter and the other as receiver you can transfer a quality audio source over 10 meters.
Where does the difference lie? this small design box has the latest technical advances in the matter with the adoption of the codec Apt-X Low Latency.
Compatible with all Bluetooth devices AD2P, it offers a reproduction very close to CD-Audio thanks to a low compression ratio. Thus, FLAC, Apple Lossless or PCM audio files are rendered almost perfectly. When files natively in MP3 or AAC (with a rate less than 350Kbits / sec), they are transmitted without decoding and without any degradation.
Byt its compact design and ease of implementation, this small receiver will allow you to listen to your favorite songs on your audio system from any Bluetooth source.
Either the vast majority of Smartphone, Tablet PC, Iphone, Ipad ...
Help in English .
Specifications:
  • Bluetooth: 3.0
  • Profiles: AD2P and AVRCP
  • Audio Codecs: Apt-X Low Latency, Apt-X, SBC, AAC
  • Range: 10m class II
  • Audio Output / Input: 3.5mm Stereo Jack
  • Rechargeable on USB port (charging cable supplied)
  • Dimensions: 50 x 35 x 15mm
  • Weight: 49g
  • Delivered: the audio connection necessary for the connection to a stereo chain (jack 3.5mm male to jack 3.5mm male + jack 3.5mm to RCA stereo).
https://www.audiophonics.fr/images2/6518/6518_ADVANCEWTX500_4.jpg
https://www.audiophonics.fr/images2/7163/7163_SATURN_TX_RX_APTX_BLUETOOTH_4.0_1.jpg
https://www.audiophonics.fr/images2/7163/7163_SATURN_TX_RX_APTX_BLUETOOTH_4.0_2.jpg
https://www.audiophonics.fr/images2/7163/7163_SATURN_TX_RX_APTX_BLUETOOTH_4.0_3.jpg
https://www.audiophonics.fr/images2/7163/7163_SATURN_TX_RX_APTX_BLUETOOTH_4.0_4.jpg
https://www.audiophonics.fr/images2/7163/7163_SATURN_TX_RX_APTX_BLUETOOTH_4.0_5.jpg
Connection:
https://www.audiophonics.fr/images2/7163/saturn-connectique.jpg
Colissimo - TNT - SoColissimo
très bon produit
super appareil, utilisation facile, plus de câble qui traîne au milieu du salon..
This review has been posted for AVANTREE Saturn Pro AFF Bluetooth 3.0 aptX Low Latency Music Adapter
