Bluetooth 5.0 apt-X HD Transmitter / Receiver CSR8675 with Battery
Emetteur / Récepteur Audio Bluetooth aptX sur batterie
4.7 / 5
Reference : 13432
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
Bluetooth Audio Transmitter / Receiver
Bluetooth 5.0 CSR8675 apt-X HD
Récepteur émetteur bluetooth nomade
This bidirectional Bluetooth Audio interface offers many wireless connection possibilities. It is battery operated and benefits from an extremely compact design. Its clever design is capable of acting as a transmitter and receiver respectively, making it an ideal accessory for enjoying Bluetooth Audio connectivity in all circumstances. For example, it can be used to connect a wired headphone to a remote device. The interface is capable of acting as a Bluetooth transmitter and receiver respectively. Two simultaneous connections can be made in order to link several devices of different types.
Intuitive and ergonomic
Bluetooth aptx HD portable
In spite of the many features offered, the device is very easy to use.  Simply connect the 3.5mm jack port to the device you wish to extend connectivity to. A sliding button on the side of the housing is used to configure the interface in either the transmitter (Tx) or receiver (Rx) position.
In receiver mode (RX) the interface will receive from an external source (cell phone, tablet, file reader...) the digital audio stream, decode it and send it in analog form to the 3.5mm jack port or digital in Toslink Optical format. The uses of the receiver mode are as numerous as they are varied: using a fixed source without sacrificing mobility, connecting speakers that are difficult to access or in a more trivial way, listening to and controlling the music on your phone without having to manipulate it.
In Transmitter (TX) mode the interface samples any analog audio signal submitted to its 3.5mm Jack or Toslink Optical port and transmits it via Bluetooth to paired devices.
Either way, the device supports apt-X and apt-X HD standards to enjoy the best compromise in audio quality and listening comfort.
The device benefits from extensive connectivity. Thus, Bluetooth, 3.5mm jack and Toslink Optics can be connected and disconnected.
Easy to carry
The device is equipped with a 160mAh lithium-ion battery. It provides approximately 18 hours of activity in transmission and reception. Charging is easy thanks to the presence of a 5V micro-USB port. Charging takes approximately two hours. Its advantageous dimensions (square of 4.37 side x 1.9 cm) for only 22g make it a comfortable object to carry that can be easily forgotten.
Pairing with model of the same type
If none of your remote devices have Bluetooth connectivity, you can use two such interfaces to pair them together. In this configuration, any device with an analog input/output can be used for remote connectivity.  This solution can bypass many integration problems.
Connection example transmitter mode
emetteur recepteur bluetooth
Please note that only one device can be connected to the 3.5mm jack at a time.
Connection example receiver mode
Emetteur bluetooth réversible
TypeBluetooth transmitter
Bluetooth receiver
Input / OutputBluetooth
Jack 3.5mm
Optical Toslink
Bluetooth standardsBluetooth 5.0 class II
apt-X
apt-X HD
aptX- LL
FastStream
SBC
Pairing LED indicatorYes
Power supply (USB Cable included)5VDC via Micro USB
SupportRX : A2DP AVRCP / TX : A2DP
Transmission / Reception distanceRX : 15m / Tx : 10m
Dimensions54 x 54 x 15mm
Weight38g
Package
Bluetooth interfacex1
Male Jack 3.5 cable 15cmx1
Male USB-A to male micro-USB cablex1
Female Jack 3.5mm to male stereo RCA adapter cablex1
InputJack 3.5mm
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipNC
6 reviews
Perfection
Branché à une box en optique pour émettre le son à un casque Bluetooth JBL, la qualité est vraiment APTX HD avec plus de 10m d'émissions
This review has been posted for Bluetooth 5.0 apt-X HD Transmitter / Receiver CSR8675 with Battery
Bon produit.
Bon produit. Intuitif et simple d'emploi. J'ai même réussi à l'appairer à des aides auditives.
Bon produit
conforme, fonctionnel, rapide. Rien à redire.
Attention, pas d'adaptateur secteur fourni, mais n'importe quel vieux chargeur de téléphone marche
Emballage sérieux, et livraison très rapide, aucun délai:
Audiophonics au top comme d'habitude :)
Pratique et efficace.
Pratique pour relier un casque filière à un DAP en mode bluetooth
et, dans mon cas, un casque bluetooth dont le mode APTX coupe sans arrêt.
Fait son travail, le résultat sonore est très correct.
Excelent Produit
Excellent produit, simple d'utilisation mais n'est pas compatible avec tous type d'appareil ( Xbox mini 4k de Bouygues Télécom)
