BURSON AUDIO SUPREME SOUND SS OPAMP V6 VIVID Dual Discrete OPA (Pair)
BURSON AUDIO Supreme Sound SS OPAMP V6 - VIVID Discrete dual OPA (A pair)
4.4 / 5
Reference : 12177
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Burson Audio Vivid Dual Pair x2
Burson Audio Vivid Dual Pair x2 AOP à Transistors Discret Stéréo (La paire)
High resolution, dynamic, balance
The AOP Burson V6 ViVid and Classics are evolutions of the V5 series with a particularly successful straight sound balance. They will bring openness, timbre, dynamics and sound image in three dimensions to any Hifi equipment compatible with DIP8 support compatible NE5534 single or NE5532 dual according to the versions.
A further improvement in design
The Burson V6 discrete AOPs are now as stable on the unity gain stage buffers as they are on the current voltage I/V stages of the DAC stages. The Burson v6 is now equipped with 0.5% metal film resistors and two hand-sorted FET stages. The VIVID version brings more definition, the classic version brings more timbre.
Reverse Protection System
A new protection system allows for greater reliability of these discrete, high performance AOPs. The Burson AOP V6 is designed to survive any upside down DIP 8 mounting accident.
Compatibility list
Dual OPA Type 5532 :
AD823, AD823AN, AD8066, AD8620, AD712, AD827, C4570, JRC4556AD, JRC4580, JRC5532, JRC5532D, JRC5534, LF353, LM4562, LME49860, LM833N, MUSES8920, NE5532, NEC4520, NEC4570, NJM2068D, NJM2114, NJM2214D, NJM4558, NJM4558D, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, OPA2277PA, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072, MUSES01, MUSES02, MUSES8820, MUSES8920, MUSES8832.
Single OPA Type 5534 :
NE5534, LT1122, TL071, OPA134, OPA627, AD811, AD829, AD844, OPA604, AD8610, AD711, AD797, LME49990, LME49710.
Product typeOPA
Minimal required voltage+/-3.5V / 7VDC
Max voltage+/-16.5V / 33VDC
ConsumptionSingle : 7mA
Dual : 14mA
Frequency response20Hz - 20kHz (-0.2dB)
Contacts typeDIP8, Gold Plating
Weight2x 10g
Dimensions29 x 12.4 x 14.5mm (hors socket)
Burson Audio Vivid Dual Pair x2 AOP à Transistors Discret Stéréo (La paire) Burson Audio Vivid Dual Pair x2 AOP à Transistors Discret Stéréo (La paire)
OPA TypeDual
7 reviews
Lecteur cd
Parfait. Très bon upgrade pour mon lecteur cd lm215. Livraison et emballage soignée. Je recommande
This review has been posted for BURSON AUDIO SUPREME SOUND SS OPAMP V6 VIVID Dual Discrete OPA (Pair)
Sharp sounding
They have a sharp (forward) sound and more details in the treble region.
LME49860 sound much better (more natural).
Upgrade de très haut niveau avec lecteur Line Magnétic LM 215 CD
J'ai voulu upgradé mon lecteur cd LM 215 sans trop y croire.
j'ai modifier mes Burr Brown 2604 d'origine par ses Burson Audio VIVID V6 sur les conseils d'un ami Indonésien passionné par le DIY de très haut niveau.
J'ai également modifier les condos de sortie du convertisseur NA sur le tube Gold Lion 12au7 par des Mundorf Mcap Evo argent or et huile.
Le niveau atteint est très dure à commenté avec des mots tant il y a à dire. S'est à la fois smoothie, savoureux dans les textures des voix, instruments (cymbales, contrebasse etc etc…), scène 3D, profondeur, réverbération, dynamique…
Dans mon cas le mariage du condo Mcap Evo et de l'AOP Burson Audio Supreme Sound VIVID V6 est WOW !!!
La tessiture des cymbales sur l'album de Avishai Cohen ( contrebassiste pas le trompettiste) est une dinguerie !!! La voix de Patricia Barber est d'une sensualité hors du commun, les solo de batterie atteint un tel niveau en texture, 3D, dynamique.
Je vais laissé rodé tout ça tranquillement.
Upgrade music hall dac 25.3: Objectif atteint!
En remplacement donc des OPA's Burr-Brown classiques montés d'origine sur ce dac: Le gain est considérable en terme de définition et de scène sonore. Fini cette purée sonore insaisissable dans les passages musicaux plus fouillés!
Je recommande pour ceux qui veulent faire monter leur système d'un cran sans passer par la case achat d'un nouveau dac de gamme supérieure...
Hmmmmmmmmmm
N'achetez pas ca ... xD
Enfin très sérieusement je trouve les muses ect bien mieux...
Vue le prix mdr... Sauf si vous êtes fortunée à la limite pour votre curiosité..
Mais pas intéressant franchement .. De mon point de vue c:
