JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 6.8µF
JANTZEN AUDIO ALUMEN Z-cap Capacitor 2.2µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
Reference : 12091
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Jantzen Audio Alumen Z-Cap Condensateur 100V 6.8µF
This series has a finer dielectric than other capacitors on the market. This avoids memory defects in the insulators for a fast transfer of electrons between each winding (very low resistance in ESR series). Janzen Audio Alumen capacitors are therefore particularly fast, offering harmonics worthy of the best oil paper capacitors, without the harmonic discolourations typical of the latter.
Jantzen Audio Alumen Z-Cap capacitors are therefore ideal for filtering high-end dome tweeters such as ScanSpeak Illuminator, Revelator, Dynaudio Esotec or SB Acoustics Satori. They are also ideal for Fountek NEO and Dayton AMT, ESS or RADIA tweeters. The welding wires are made of OCC Copper. These capacitors are also excellent for coupling in transistor amplifiers where the nominal voltage is sufficient (100VDC).
Product typeCapacitor
DielectricPolypropylene (PP)
Aluminium metalization99.99%
DC Voltage100V DC
Tolerance+/- 3%
Max temperature85°C
Vers low induction-
PolarizationNon polarized capacitors
Very low resistanceESR
DimensionsØ31 x 105mm
Weight63g
Tolerance (%)3.0
Capacitor capacitance6.8
Rated voltage (V)100.0
Capacitor typeFilm capacitor
Capacitor formatAxial
3 reviews
Excellent condensateur mérite l'investissement
Il faudra être patient pour obtenir le meilleur de ce condensateur ( environ 100 heures et le "bouchon" saute). Idéal sur le filtre médiums hauts - aigues en particulier avec des tweeters à ruban. Je l'utilise sur une 2 voies filtrée en 12 DB avec un Ess Amt. Après des Mundorf Suprème qui étaient déjà très bons, les Alumen m'ont fait passer de la 2D à la 3D avec beaucoup de détails, tout devient précis, les médiums s'expriment, les voix sont magnifiques, le son devient naturel , les ambiances concert sont retranscrites parfaitement.
This review has been posted for JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 6.8µF
Sublime, sublime
Que dire de plus que dans les descriptif, je les ai remplacés en lieu et place de Mundorf pourtant excellent.
Certes l'investissement est relativement important, mais la différence est sans commune mesure.
J'ai eu l'impression de changer d'enceintes, tellement la différence est importante sur mes tweeters ScanSpeak Revelator.
Je recommande sans aucune hésitation.
Un grand merci à Audiophonic de les avoir commercialisés
ALUMEN Z-CAP 100V 6.8µF
Very decent sound. Nothing more, just music.
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium...
