SMSL Sanskrit Pro-B DAC AK4490EQ 32bit/384khz DSD 256 Bluetooth aptX
SMSL Sanskrit Pro-B DAC AK4490EQ 32bit/384khz DSD Apt-X Bluetooth 4.0
Reference : 11159
179,00 €tax incl.
149,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Dramatically evolving from the now famous SMSL Sanskrit PRO-B, this powerful converter offers you the possibility to read your high resolution PCM files up to32bit 384kHz and DSD256.
The SMSL Sanskrit Pro-B has 2 coaxial and optical Toslink S / PDIF inputs, a USB-B 2.0 input. and an analog RCA stereo output.
Versatile, it also gives you the opportunity to exploit this potential remotely with a built-in Bluetooth 4.0 module with NFC support. This new generation now incorporates an external Bluetooth antenna for better wireless reception and more stable without microswitch.
Utdigital output, this device acts as a particularly powerful DAC.
heincludes an Asynchronous C-Media USB interface CM6632A with a special SMSL firmware associated with an AK4490EQ AKM converter: a surprisingly efficient pair.
The Sanskrit Pro-B can be connected to any device with digital audio coaxial outputs or transmitter Bluetooth: TV, CD / DVD / HDD NAS drives.
SMSL Sanskrit Pro review by Qobuz
" This is certainly a DAC that lacks virtually nothing in format decoding capabilities, even if food for some of them remains very scarce. In addition, it is compatible with smartphones and tablets running Android and iOS and offers very good sound results. All this in a pretty and discreet little box at a price affordable to a large number of amateurs, who will complain about it? "
Test Qobuz
Features:/ Strong>
  • DAC AKM AK4490EQ
  • USB interface C-Media CM6632A (SMSL version) Asynchronous (32bit 384kHz, DSD 2.8MHz, 5.6MHz)
  • Bluetooth Module 4.0
  • Range: 7 meters
  • Apt-X Lossless / Lossless Audio Transmission
  • Jitter extremely low
  • THD + N: 0.0006% to -3dBFS
  • RNoise signal input: 120dB
  • Dynamic range: 118dB
  • Frequency response: 20Hz - 25kHz to -0.3dB
  • USB 2.0 port
  • Inputs: Coaxial S / PDIF, Optical Toslink (24bit 192kHz)
  • Output: RCA Stereo
  • Chassis 100% Anodized aluminum
  • Dimensions: 144x98x36mm
  • Weight: 850g
  • Power supply 9V DC 1.3A included
  • USB-A to USB-B 2.0 cable provided
Illustration system with devices in the range.
DAC / ADC ChipAK4490EQ
Max sampling rate384kHz
ColorSilver
