ELECAUDIO PS-24GB Schuko Type E/F Power Connector 24K Gold 3μ Ø16.5mm Black
ELECAUDIO PS-24GB Prise Secteur Schuko Noir Or 24K 3µ Ø16.5mm
The Schuko PS-24GB reference plug is distinguished at first glance by its anthracite-black nylon body with an impeccable finish and ideal proportions. This chassis can accommodate the most sophisticated cables, the diameter of which is often incompatible with conventional mains sockets.
4.6 / 5
Reference : 6582
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Elecaudio PS-24GB
Socket Schuko Black Gold 24K 3μ Ø16.5mm
ELECAUDIO PS-34GB Connecteur Secteur Schuko Noir Or 24K 5µ Ø16.5mm
The Schuko PS-24GB reference plug is distinguished at first glance by its anthracite-black nylon body with an impeccable finish and ideal proportions. This chassis can accommodate the most sophisticated cables, the diameter of which is often incompatible with conventional mains sockets. With its insertion ring limiting the diameter to 16.5mm, supported by a flexible rubber cable clamp to complete the integration, the PS-24GB easily accommodates cables with a large cross-section.
All metal parts, including the contact and earth poles, were plated 3µ gold. This plating on the entire surface of the contacts provides better conductivity than a standard plating.
The internal connection terminals also deserve attention: Equipped with large fixing screws, and therefore requiring no soldering, they are capable of receiving large diameter conductors and ensuring a firm hold over a particularly large contact surface. Finally, we will appreciate the small diagram directly engraved into the socket, which provides information on the optimal length of cable to strip.
Product tyipeSchuko connector
Connection typeTo screw (BTR screw)
PlatingGold 24k 3µ
Max conductors section16mm² (4.5mm diameter)
Max cable diameter16.5mm
Voltage / Current250V / 16A
Total length89mm
Diameter38mm
Weight75g
Schéma de câblage
Max cable diameter (mm)16.5
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
18 reviews
Good plug
Look solid with good gold plate
Best plug for price
This review has been posted for ELECAUDIO PS-24GB Schuko Type E/F Power Connector 24K Gold 3μ Ø16.5mm Black
attention au branchement
Très bonne prise achetée pour montage cordon secteur en DIY. Par contre suite à connexion sur barrette secteur dynavox X4100, allumage de la led Inversion de phase. Après recherche du défaut , le cordon est en cause : inversion phase et neutre au niveau de l'inscription N et L inscrit au niveau insertion des fils: Donc à ne suivre pour le branchement.
Par contre le schéma de branchement donné par le site est correct
Perfect connector
Nicely finished, excellent quality for your high-end cable.
Françis S
On peu trouver des prises de bon maintient dans le commerce de bricolage , mais pas avec des fiches qui ne s'oxydent pas dans le temp . Donc, si l'on veux une installation propre , c'est une bonne solution ,qui permet d'être sur de ses contactes .
Excellent schuko plugs
Lots of space to connect the wires with no problems, superb screws that allow for the correct pressure over the wires, and the cable rests correctly attached to the plug. Shinning golden contacts and screws.
The Schuko PS-24GB reference plug is distinguished at first glance by its anthracite-black nylon body with an impeccable finish and ideal...
