AUDIOPHONICS RaspDIGI Network player Raspberry Pi 2.0 SPDIF
The RaspDIGI is a variation of the RaspDAC equipped this time with a digital interface I2S Digipi + to enjoy your audio files in a low jitter solution.
Reference : 10631
249,00 €tax incl.
207,50 € tax excl.
AUDIOPHONICS RASPDIGI
Digital network reader Digipi + and Raspberry Pi 3
RaspDAC
This 100% Aluminum case receives a Raspeberry Pi 2.0 motherboard with a Digipi + low jitter digital interface and all necessary components. The RaspDIGI is developed and assembled directly in our workshops.
Complete ready-to-use network reader with only the software solution of your choice (Volumio, Picoreplayer, Raspbmc, Openelec).
A high-end audio player ...
Based on a digital interface capable of converting sampling rates up to 24bit 192kHz, it will allow you to obtain very simply a high-end Audio or Audio / Video player. This streamer player allows DSD and DXD playback through its USB class 2.0 output.
It has all the necessary inputs / outputs, its power supply (jack DC 5.5 / 2.1mm), an HDMI port as well as an OLED display. Equipped with high-end coaxial connectors and BNC 75 ohms, the RaspDIGI faces all the scenarios of video as well as audio.
RaspDAC
Your Raspberry Pi in a high quality Audio environment.
It has been designed with the aim of allowing you to have the effectiveness of your Raspberry Pi in a high quality Audio environment. Especially elegant and discreet, it offers you the possibility to have a powerful audio solution and achieved an excellent value for money.
RaspDAC
SpecificationsRaspberry Pi 3Model BDigital interfaceAudiophonics Digipi + I2SdisplayOLEDinputs1x RJ45 / 4x USA-A / Port Micro-SD AccessibleExits1x HDMI / USB (32bit 384kHz) / 1x Coaxial SPDIF (24bit 192kHz) / 1x BNC (24bit 192kHz)FoodJack DC 5.5 / 2.1mmDimensions160 x 140 x 50mmDisplay Size65 x 16mmWeight0.9kgHousing material100% AluminumColorBlack
Aluminum Case for Digipi + Raspberry PI A + B + 2.0 i2S & Raspberry Pi 2.0 / 3.0
This 100% Aluminum case has been designed to accommodate the Raspberry Pi 2/3 &AUDIOPHONICS Digipi + Raspberry PI A + B + 2.0 i2S.
RaspDAC housing
Supplied accessories:
To allow you to be directly operational, the player comes with a USB to power cable and an 8GB SDHC card. It will however be necessary to provide mains power to 5V with USB A 2A connector (or connect it to a computer).
Volumio
The RaspDIGI is a variation of the RaspDAC equipped this time with a digital interface I2S Digipi + to enjoy your audio files in a low jitter...
