MATRIX Mini-i AD1955 V2 USB DAC SPDIF - XLR - RCA - Headphones
MATRIX Mini-i AD1955 V2 DAC USB SPDIF - XLR - RCA - Casque
4.5 / 5
Reference : 5034
299,00 €tax incl.
249,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
MATRIX AD1955 Mini-i DAC (Version 2011)
DAC with USB inputs - BNC (SPDIF) - Toslink - AES / EBU
RCA - XLR Variable Outputs - Headphone Amplifier + Remote Control Aluminum
This unit is a Digital - Analog Preamplifier XLR and Headphone Amplifier.
Despite its average size it is equipped with all existing digital inputs, two types of analog outputs, a headphone amplifier.
It even has an SPDIF output to convert the signal to the digital inputs.
This may be useful, for example, for a DTS or AC3 signal arriving in optics and needing to be decoded externally by a DTS decoder.
The XLR and RCA outputs are variable through the volume knob which is an endless potentiometer. (-90dB to -0dB)
The sound level is recorded when turned off, so this unit can really be used as a digital preamp and placed at the top of your Hi-Fi system.
The inputs are selected by pressing the same button.
The decoder scheme is symmetrical, it uses two converters based on the AD1955 Analog Device already used on very high-end devices.
Thee receiver is an AK4113 with low Jitter and chip amplification headphone TPA6120.
Features:/ Span>
  • Diagram100% symmetrical
  • Decoding chips 2x AD1955
  • Up to 24Bit / 192kHz
  • Receiving chip AK4113 low jitter
  • Integrated headphone amplifier, up to 300ohm
  • Outputs XLR and RCA audiophile quality variables
  • Allows to be used as preamp or simple DAC (without volume control)
  • Comes with Infrared Control Remote Control (Volume Control, Mute, Power On / Off and Source Selection)
Digital Inputs:
  • Toslink optics from 44.1 to 192kHz
  • Coaxial: 75ohm RCA or BNC (supplied adapter) from 44.1 to 192kHz
  • AES / EBU: XLR symmetrical 5v from 44.1 to 192kHz
  • USB: 44.1 or 48kHz USB-B connector (PC only)
Digital Outputs:
  • SPDIF Coaxial
  • 44 to 192kHz according to input
  • Allows even redirecting an AC3 or DTS stream
Analog Outputs:
  • RCA: 0 ~ 2V variable volume
  • XLR: 0 ~ 4V variable volume
  • Frequency response: 20Hz - 20kHz
  • Signal to noise ratio: 105dB
  • Dynamic range: 108dB
  • Distortion: 0.0002% @ 1kHz
Others:
  • Weight: 1.2kg
  • Dimensions: 205x155x48mm
  • Power Consumption: 15W
  • Supplied with: Power cable, B adapterNC -> RCA3
</ P>
</ P>
https://www.audiophonics.fr/images2/5034/5034_Matrix_mini-i_AD1955_DAC_8.jpg
https://www.audiophonics.fr/images2/5034/5034_Matrix_mini-i_AD1955_DAC_7.jpg
Internal view:
</ P>
Digital inputs:
Pair of AD1955 converters:
InputXLR
OutputCoaxial SPDIF
DAC / ADC ChipAD1955
Max sampling rate192kHz
ColorSilver
2 reviews
Après deux semaines d'utilisation je suis vraiment ravi de ce convertisseur, le son est aéré, précis, tous les instruments sont en place, il a vraiment une belle image stéréo.
Je l'utilise principalement avec le PopPulse PC LINK en AES/EBU acheté sur ce même site.
L'entrée numérique optique ne démérite pas non plus, ma passerelle multimédia avait un son plutôt plat avec sa sortie analogique, la bande son des films est enfin dignement restituée.
La finition de l'appareil est également irréprochable, bref, un rapport qualité prix imbattable pour ce DAC.
Enfin, la livraison fut ultra-rapide et l'emballage impeccable.
This review has been posted for MATRIX Mini-i AD1955 V2 USB DAC SPDIF - XLR - RCA - Headphones
Un bon convertisseur pour aborder le monde de la musique dématérialisée.
Je l'utilise de la manière suivante :
- entrée optique venant de la BOXTV.
- entrée USB venant du PC
- sortie directement sur un bloc de puissance NAD 216THX.
Gain : pas besoin de préampli, la télécommande du MATRIX gère tout !
Problème : des "plocs" désagréables à la mise ON ou lors du changement d'entrée.
