WBT-0708Ag Silver speaker terminals (Set x4)
WBT-0708Ag Borniers pour haut parleur plaqués Argent (paire x2)
By buying this product you get 26 loyalty points
Reference : 8650
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 02-05-2024.
Shipping from France
Billing in France
Technical support in France
WBT-0708 Terminal blocks for pure silver speaker (set x4)
Coming from the latest generation of development by WBT, the Nextgen 0708 AG is fitted with Pure Silver conductors.
Thanks to the separation of the transmission line and the mechanical chassis, it is now possible to use superior quality materials for each of the elements of this terminal block. Although it is a better electrical conductor, copper or silver have some mechanical limitations which we have overcome by the use of high performance plastics.
In addition, the soul of this new terminal block consists of a single piece, thus avoiding any unnecessary resistance. The signal conductor is protected by a glass fiber matrix reinforced with mineral plastic and covered by a non-magnetic steel body. An additional elastomer damping system drastically limits the vibrations transmitted to the driver. The microphone effect is thus greatly reduced in favor of the precision of the transmitted sound signal.
The design of this product makes every effort to ensure the best electrical isolation.
SPECIFICATIONS :
  • Max conductor cross-section : Inner : 4mm² (11 AWG) / Outer: 4mm² (11 AWG)
  • External connection : Banana plugs 4mm, spades6 ou 8mm, bare wire.
  • Internal connection : Weld or 6.3 flat connector.
  • Panel mounting thickness : From 0.9 to 6.5mm with Puzzle plates and 4.5mm to 6.5mm without plates
  • Identification : 2 x red, 2 x white
  • Pure Silver
https://www.audiophonics.fr/images/8650_wbt_0708ag_borniers_1.png
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)6.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Contacts Material (Connector)Silver
Ne pas hésiter
En remplacement des borniers d’origine sur un NAD C368, vraiment rien à dire ou plutôt si, on gagne dans tous les domaines et notamment sur celui de la scène sonore, elle est plus large et plus profonde. Il y a plein de détail et micodétail supplémentaires, on localise beaucoup plus facilement chaque instrumentiste. Evidemment il faut derrière le câble Hp qui va bien. vaut largement son prix.
jm
This review has been posted for WBT-0708Ag Silver speaker terminals (Set x4)
