WBT-0703Ag Terminal blocks for loudspeaker Silver (Set x4)
WBT-0703Ag Borniers pour haut parleur Argent (Set x4)
By buying this product you get 26 loyalty points
Reference : 8649
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
WBT-0703ag Terminal blocks for silver speaker (x4)
Coming from the latest generation of development by WBT, the Nextgen 0703 ag is fitted with silver conductors.
Thanks to the separation of the transmission line and the mechanical chassis, it is now possible to use superior quality materials for each of the elements of this terminal block. Although it is a better electrical conductor, copper or silver have some mechanical limitations which we have overcome by using high performance plastics.
In addition, the soul of this new terminal block consists of a single piece, thus avoiding any unnecessary resistance. The signal conductor is protected by a glass fiber matrix reinforced with mineral plastic and covered by a non-magnetic steel body. An additional elastomer damping system drastically limits the vibrations transmitted to the driver. The microphone effect is thus greatly reduced in favor of the precision of the transmitted sound signal.
The design of this product makes every effort to ensure the best electrical isolation.
SPECIFICATIONS :
  • Max cross section conductor : Internal & external 4mm² (11 AWG)
  • External Connection : banana plug 4mm, spades 6 ou 8mm, crimped bare wire.
  • Connexion interne : Weldou or 6.3mm flat connector.
  • Panel mount max thickness : from 0.9 to 10mm
  • Identification : 2 red, 2 white
  • Silver conductors
  • Documentation PDF
https://www.audiophonics.fr/images2/8649/8649_wbt_bornier_0703ag_1.png
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Contacts Material (Connector)Silver
2 reviews
précision
vous indiquez dans la partie fiche technique :
Plaquage Argent
Matériaux Cuivre
je confirme que ces connecteurs possèdent des contacts en argent pur.
D'autre part, toutes les versions Nextgen Argent représentent les meilleurs que j'ai pu rencontrer, du point de vue de la qualité subjective.
This review has been posted for WBT-0703Ag Terminal blocks for loudspeaker Silver (Set x4)
qualité
le changement et le montage sont faciles à réaliser sur deux amplis monophoniques. Très belle réalisation de qualité. L'apport au niveau du son n'est pas spectaculaire: son ciselé et hyper dynamique qui ne correspond pas à la réalité. mais un apport riche et subtil: positionnement des pupitres dans l'espace gauche-droite et avant-arrière, qualité des timbres des instruments, la scène sonore plus aérée, bande passante plus étendue. Je réécoute mes CD avec plaisir et je découvre une musicalité gravée que je n'entendais pas avant. Attention, il faut être cohérent dans le parcours du signal électrique: argent ou cuivre-argent. Réf: dossier optimisation par jean Hiraga, l'importance des contacts électriques, Stéréo prestige novembre 2014
