WBT-0735 Fully insulated loudspeaker binding post (Set x4)
WBT-0735 Borniers pour haut parleur isolation totale (La paire)
By buying this product you get 25 loyalty points
Reference : 2304
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Since we know that a simple electrical wire is no longer enough to connect amp and H.P., we have become accustomed to using cables with a large cross-section, which has had some repercussions on the terminal blocks...
This type of connector is confronted with two imperatives:
It is not only a question of accepting large cable cross-sections, but above all of ensuring - thanks to extreme clamping - excellent conductivity.
The truth is therefore not in giant terminals, but rather in a mechanically very robust construction.
The integrated retaining mechanism (WBT patent) holds the banana plug firmly in place when the front locking nut is tightened and thus not only protects the connection against accidental disconnection but also ensures extremely high contact pressure.
Long before the arrival of CE standards for the European market, WBT had already launched its 'Safety' system for high-power connections:
The high-power terminals, banana plugs and fork terminals of the Safety-Line WBT are the best in connection technology.
Design and elegance in the service of safety, the "do not touch" is a thing of the past, and the whole unit is fully insulated in accordance with EN 60065 and IEC65 standards.
Comfort of use and compatibility with established systems is all there!
The 'Safety Line' series is designed for the discerning amateur and professional user.
  • 68% copper alloy
  • Machined in the mass
  • Maximum thickness of the substrate: 10 mm
  • Total insulation
  • Sold by 4
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
