JANTZEN AUDIO C-COIL 000-6355 4N Copper 17AWG Ø1.2mm 6.8mH 0.17 Ohm
JANTZEN AUDIO C-Coil 4N Copper 17AWG/1.2mm 6.8mH
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from overheating and without causing distortion.
Reference : 16005
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Bobine filtrage basses
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from overheating and without causing distortion. The model in question tolerates up to 500W (RMS) / 8Ω . In fact, they are particularly efficient for bass induction when filtering your passive hi-fi speakers.
Attention, because of the electromagnetic field inherent to their construction, the C-Coils will not be suitable for a crossover rising beyond 1.20kHz. Also, they are not intended for amplification or any other active system.
Each coil is individually tested with the CLIO @ AC 1V 1kHz measurement system.
Product typeC-Coil
MaterialETP Copper C11000 standard / IACS certified
CoreEpoxy insulated metal
Inductance6.8mH +/-5%
Power handling (RMS)500W (RMS) / 8Ω
RDC0.17 Ohm +/-10%
Outer diameter71mm
Height25mm +/-3
Inner diameter-
Wire diameter1,2mm⌀
Cable section1.04mm² (17AWG)
Weight360g
Inductance (mh)6.8
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from...
