AUDIOPHONICS I-Sabre V2.1 DAC ES9023 TCXO Raspberry Pi 3 / Pi 2 A+ B+ / I2S
10%
Reduced price!
Reference : 11917
Limited special offer
64,90 €tax incl.
-10%
58,41 €tax incl.
48,67 € tax excl.
Available
Shipping date: 25-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Updated I-Saber TCXO V2, its architecture is designed to allow you to have all the outputs on the same side when the Raspberry Pi is coupled to the DAC.
This version 2.1 has been redesigned to simplify the connection of the OLED Wins screentar WEH001602Aand to easily integrate an external power control module (ex: PI-SPC Pre-welded ATX power control module )
Our specially designed aluminum boxes make it easy to integrate the DAC (sold separately).
This module is ideal for transforming a Raspberry Pi 2.0, A + or B + into a high-definition file player. This converter offers unbeatable value for money with direct analog outputs on high-quality headers.
Equipped with the now famous SABER ES9023 (equipped with our U-SABER), Ultra low noise "ON" regulator and condenser OS-CON this DAC will offer you musical sound and rich micro details.
Its high versatility (GPIO B + or A + HAT format connector (for PI) as well as I2S inputs) allows it to be also usable from a USB interface or any I2S source.
Features:/ Strong>
  • High Precision Clock TCXO 0.5ppm ultra low jitter
  • I2S input on 5 pin XHP connector
  • DC Input Jack 5V - External Diameter 5.5mm / Internal Diameter: 2.1mm (not required if the PI is powered by the Micro USB port)
  • Input: Raspberry PI B + A + 2.0 GPIO and I2S
  • Output: RCA High Quality Gold Plated
  • Supported sampling rates: 24bit 192kHz
  • No welding required
  • Supplied with 4 nuts, 4 screws and 4 spacers M2.5 to fix it on the PI B +, A + or 2.0 (HAT format)
  • Spacing: 50mm, 58mm
  • PCB Dimensions: 85x56x33mm
  • I2S driver: Hifiberry DAC
  • Volume fixed under Volumio in bitperfect
Dimensions and weight:
  • Dimensions: L x W x H: 106x56x32.5mm (overall)
  • Center distance fixing: 50x60mm
  • RCA cinch distance: 20mm
  • Weight 64gr.
Can be used with:
Max2Play Volumio piCorePlayer
Support piCorePlayer 1.21b
PDF manufacturer
OLED, IR AND I2S DISPLAY CONNECTIONS
INTEGRATION DIAGRAM ATX POWER CONTROL MODULE
(The power module is sold separately and can be found by following this link)Intégration du module de contrôle d'alimentation ATX
SPECIFIC RATINGS OF REAR LOCATION WITH PI 3:
Cotations I-Sabre V2.1
ComponentES9023
ColorNoir
ConnectionScrew
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
Excellent raport qualité prix
J'ai acheté ce DAC pour me faire un RASPTouch avec une Pi3 et un contrôleur ATX avec KODI sur XBian. Configuration basique facile, est reconnue comme un DAC Hifiberry, donc quasi natif sur une Xbian.
Le son est à la hauteur, voir au delà de mes attentes. Les graves autant que les aigus sont restitués avec une grande finesse.
Je le conseille sans aucun problème. Pour ceux qui veulent moins de composants, la V3 intègre un module de contrôle d'alimentation, on pourrait donc se passer d'un contrôleur ATX...
This review has been posted for AUDIOPHONICS I-Sabre V2.1 DAC ES9023 TCXO Raspberry Pi 3 / Pi 2 A+ B+ / I2S
perfect sound
It took long to decide which DAC I should buy, finally I ordered also the AUDIOPHONICS Linear Regulated Low Noise Power Supply USB 5V 3.5A 25VA and in just 5 minutes the setup was playing.
I am really surprised that a DAC can do so much in the sound on the same setup.
So the source is indeed the first important step.
At this price a big improvement over the HiFiberry DAC+ Pro
