This E-9818 600:10k permalloy transformer can be used for a wide range of applications. It can be used, for example, to convert a balanced signal into an unbalanced one and vice versa, or to isolate an audio signal from the other circuit, avoiding unwanted noise generated by the circuit itself. With its near-perfect decibel variation of just +/-0.18 dB over a frequency range from 20Hz to 20kHz, you can rely on this transformer to deliver Hi-fi quality. Furthermore, the E-9818 600:10k transformer comes with its own PCB, to ensure compatibility with the system in which it will be installed.
Product type | Audio transformer |
Transformation ratio | 1:1 |
Spacing betwen pins | 6mm |
Spacing between rows of pins | 13.5mm |
Inductance between the two coils | ≥ 20H |
Frequency response | 20Hz - 20kHz |
Loss across transformer | +/-0.18 dB |
Dimensions | 20 mm x 20mm x 18.3mm |
Weight | 28g |
Package | 1x Audio Transformer E-9818 600:10K 1x Compatible PCB |
