SMSL Q5 PRO FDA Amplifier TAS5342 2x45W + Subwoofer output 4 Ohm CS5341 SA9023 Silver
SMSL Q5 PRO Amplifier TAS5508 2x 45W CS5341 SA9023 24bit 192kHz Silver
4.7 / 5
Reference : 10393
115,00 €tax incl.
95,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
With a Cirrus Logic CS5341 converter and an SA9023 embedded USB interface, the SMSL Q5 Pro (latest revision by the manufacturer) is a particularly gifted amplifier.
It integrates a Texas Instruments TAS5508 + TAS5342 amplifier module delivering 2x 45W at 4 Ohms and 2x 25W at 8 Ohms.
This pro version now includes a Subwoofer output (SW OUTPUT) specially designed for subwoofers.
Versatile, it allows you to assign it 4 sources (stereo 3.5 jack, Coaxial S/PDIF, Toslink Optics and Micro USB).
It has a digital display and a remote control for easy control.
Its internal architecture as well as the choice of materials and finishes are all assets that make the Q5 a particularly efficient amplifier suitable for a wide range of configurations.
SMSL Q5 Pro review by Qobuz
" It must be recognized that this full digital amplifier S.M.S.L.Q5 pro provides, with a really small footprint and low calorie emission, sound results that can satisfy demanding amateurs, including us. A very surprising technology. "
Test Qobuz
  • Cirrus Logic CS5341 Converter
  • Texas Instruments Digital Amplifiers TAS5508 + TAS5342
  • S/PDIF Cirrus Logic CS8422 S/PDIF interface
  • Asynchronous USB interface SA9023
  • Support for files up to 24bit 96kHz (USB) and 24bit 192kHz (S/PDIF)
  • Max. power output 2x 25W under 8 Ohm, 2x 45W under 4 Ohm
  • Frequency response: 20Hz - 22kHz to +/- 3dB
  • Signal-to-noise ratio: 81dB
  • Dynamic range 102dB
  • THD+N : 0.05%.
  • Inputs : 3.5 stereo jack, Coaxial S/PDIF, Toslink optics, Micro USB
  • Hp terminal block output accepting banana plugs
  • Subwoofer output filtered at 100Hz
  • Volume control
  • On/Off switch
  • Max. consumption : 102W
  • Frame Aluminium CNC machined anodized Silver
  • Front Anodized Aluminium Front Silver Anodized Aluminium
  • Dimensions: 137x103x33mm
  • Weight: 1.1kg
  • Power supply (19V 6.3A jack 2.5 / 5.5), remote control (battery not included) and Micro USB cable included
  • Android 4.0 and higher compatible in USB OTG
Qobuz
Test in French (Click here)
InputJack 3.5mm
OutputSubwoofer
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipTAS5508
Power (W)25.0
7 reviews
presque parfait
les +
petit ampli efficace pour alimenter des JBL control one, il s'en sort parfaitement.
design sobre et efficace.
nombreuses connectiques pour le prix au vue de la concurrence.
les -
le volume se fait par pallier, c'est dommage.
Et on finit par le moins bien, il n'y a pas de vrai bouton on/off, bref on ne coupe jamais le courant de cette ampli qui reste en veille et chauffe tout le temps. Voilà clairement un problème de conception qui aurait pu être évité.
This review has been posted for SMSL Q5 PRO FDA Amplifier TAS5342 2x45W + Subwoofer output 4 Ohm CS5341 SA9023 Silver
JOLIE SURPRISE
Gros comme deux paquets de cigarettes ( je ne suis pas fumeur ) branché dans mon bureau sur mes gaia minor , ce petit ampli a tout d'un grand . Même connecté sur mon système principal beaucoup plus ambitieux il ne déçoit pas . La finition n'appelle aucune critique tout comme le service d' audiophonics . Achat très recommandable .
Magic Ampli ;)
Avec ce petit amplificateur au son insoupçonné, je redécouvre mes enceintes Radius Audio Monitor et ce , beaucoup mieux qu'avec mon ancien DENON PMA-710 AE moins dynamique...Étonnant ! Et par dessus le marché, il est d 'un excellent rapport/qualité prix ,à acheter sans hésitation ! J'ajouterais aussi, l'impeccable service d'Audiophonics,merci à l'équipe. ( NB;écoute sans subwoofer)
Superbe
Ce petit ampli est vraiment étonnant, rapport qualité prix imbattable.
Pour avoir testé les tout premiers amplis FDA (tripath) je mesure le chemin parcouru par cette technologie qui, à mon avis, et à très brève échéance remplacera avantageusement les amplis analogiques.
La première qualité de cette technologie est effectivement sa très grande transparence , cela saute aux oreilles dès les premières écoutes, j'ai quand même pu lire dans les commentaire de l'ad18 (autre ampli fda smsl) une personne déclarer que son ampli à lampe était plus transparent que le fda, comment dire... étant moi même possesseurs de plusieurs amplis à lampes et même si j’apprécie énormément le son de ces matériels , leur qualité première n'est pas vraiment la transparence, je ne connait rien qui ne colore plus le son que la lampe, et c'est d'ailleurs ce que l'on recherche dans cette technologie, bref avec ces fda nous sommes loin de la lampe c'est sur et c'est tout bénéfice pour la transparence, je recommande à chacun de se faire sa propre opinion, au vu du prix l'expérience en vaut la chandelle, pour ma part je vais certainement commencer à réfléchir concernant la migration de mon système principale ( à base de lampes) vers du fda.
RQP INCROYABLE
SUPER APPAREIL
RQP incroyable
Pour un prix ridicule il en met plein la vue à des appareils 20 fois plus chers
A acheter les yeux fermés
